Torquing down Supercharger tensioner with torque wrench
Old 09-03-2016, 04:51 PM
cheddaboy's Avatar
Default Torquing down Supercharger tensioner with torque wrench
I have recently swapped my 3.8" pulley for a 3.6" and I am reading lower boost. My only conclusion is that the belt is slipping. I have a 6.75" pulley on the crank and made 17.5-18 psi @8000 with a 3.8" pulley. With the 3.6" pulley I am logging 13.8 -15 psi. I now question my belt tightness. Is there a more accurate way to measure the tightness of the belt other than the twist test? I've read that you can use a torque wrench on the tensioner and that should give you an idea of how much its pushing on the belt.
Ideas?
Old 09-05-2016, 11:01 AM
dshea's Avatar
Make sure the nut that secures the tensioner is torqued to spec. I use this adapter with an adjustable wrench to get around the clearance issue: https://www.amazon.com/Motion-Pro-08...wrench+adapter
Once you know you've been tightening the nut properly, you can eliminate that as a variable. Then you can experiment with the belt tension until you get what you expect.
Old 09-05-2016, 11:07 AM
E4RTH WORM JIM's Avatar
Tighten it until is stops slipping! That's the correct amount of tension.
Loads of people use that pulley size and smaller without slippage so you won't do any damage if you keep adjusting it until it stops.
_brandon
04-02-2023 09:57 PM
Aliminator
08-17-2012 04:15 PM
Hot.Damn
12-07-2006 06:21 PM
MB
12-21-2005 05:47 AM
Quick Reply: Torquing down Supercharger tensioner with torque wrench
