Tracking down hi-idle issue-picture
Old Sep 15, 2012 | 11:20 AM
s2kseven's Avatar
Default Tracking down hi-idle issue-picture
After said and done -- I got the car running but I can't trackdown why the hi-idle (3,000rpm). This car does not have much vacuum except:
one for fuel regulator, one for the BOOST gauge. Nothing else I need and I blocked them all.
Even it's hot the idle will not go down to 3,000rpm. I have AEM EMS ecu.
I reset the TPS reading 0.30 at close (resting) and 4.5V at wot. The idle valve are all connected. The idle screw in the right adjustment.
Any idea where to hunt?
Here is the engine picture http://imageshack.us/a/img29/1213/7engine001.jpg
http://imageshack.us/a/img191/6008/7engine002.jpg
You see, it's a simple setup but where did I go wrong?
thank you
Old Sep 15, 2012 | 04:27 PM
hybridsol's Avatar
1. IAC full open
2. Vacuum line/port not connected
3. Throttle cable holdding throttle open
I'd start with #1- I don't know AEM, but try disconnecting IAC valve while car is in high idle- if it dies, that's your problem. If not dosconnect the throttle cable. After that, listen for a open vacuum line.
Old Sep 16, 2012 | 03:02 AM
s2kseven's Avatar
Thanks Hybrid---i appreciate the help
Old Sep 16, 2012 | 06:09 AM
sohc_mshue's Avatar
Like hybrid said unplug iacv. If it still idles high then it is not tune related. You either have a leak or throttle plate is stuck open. Spray carb cleaner arount intake mani to check for leaks.
Old Sep 16, 2012 | 07:38 AM
SgtB's Avatar
You do have a good PCV valve right?
Old Sep 16, 2012 | 08:02 AM
s2kseven's Avatar
Yeah I cleaned the PVC and would like to test it.
For some reason, the car sputter - sometimes it will start and stop -- sometimes it will not start.
I think something wrong with my crank sensor. The anti freeze overflowed in the crank sensor area and something happened.
Thanks
CynicG
Jun 23, 2017 01:57 PM
whitedxi
Feb 25, 2014 11:02 PM
myflys2k
Jun 15, 2013 11:03 AM
00s2k9k
Sep 28, 2009 09:49 PM
YuriArts
Feb 9, 2009 01:44 PM
