traction control
Old Jan 24, 2010 | 02:49 PM
josserman's Avatar
Default traction control
any of you guys use traction control? I'm thinking about turning it on in my ems when I get my retune.
Old Jan 24, 2010 | 03:26 PM
m R g S r's Avatar
set up boost by gear. although you can only go as low as your WG spring.
Old Jan 24, 2010 | 05:34 PM
Spoolin's Avatar
Im not too sure how the traction control feature works on the AEM EMS but I have been using boost by speed and it works great.
Old Jan 24, 2010 | 05:54 PM
camuman's Avatar
x2
Old Jan 25, 2010 | 06:33 AM
josserman's Avatar
thanks Jeff....since you mention it's more for straight line does it cause issues in turns? Since in a turn wheels spin at different speeds (of course the diff helps this), does that confuse the system?
Old Jan 25, 2010 | 07:19 AM
deathsled's Avatar
no, because it was just said that the AEM TC is not monitoring wheel speed....
Old Jan 26, 2010 | 06:08 AM
dammitjim's Avatar
Search on Racelogic if you want a conventional traction control.
Old Jan 27, 2010 | 05:36 AM
flexer's Avatar
Originally Posted by Evans Tuning,Jan 25 2010, 05:00 AM
Justin,
I can set it up, but the conditions will have to be right on the street tune in order to get enough data to set-up the trip tables for each gear. If its raining or wet, I cannot get the right data.
The TC works, and very well at that. I like to have a toggle switch mounted into the car to be able to turn it on/off. The TC is meant for straight line conditions, not so much cornering the way that AEM has it set-up. If it used wheel speed sensors and % slip rate that would be a different story.
The new series 2 boxes are going to have a ground speed limiting feature that is within the same idea as TC, but MUCH easier to set-up. Again, its more for straight line acceleration but is bad-ass.
Evans is right for the most part.
While he says its GREAT for straight line I would give it a rating of "acceptable". Also he is correct it is USELESS for corning.
A wheel speed type device and monitoring system is needed to really have a traction control set-up like you might find with Racelogic.
But Evans is going to have a lot more experience than me with the new Box. So if he says there are going to be improvements with the new box then we will have to wait and hear from him on how things go.
J. R.
riceball777
Sep 26, 2011 05:27 AM
camuman
Jul 21, 2011 08:11 PM
AusS2000
May 5, 2011 06:50 AM
SPECIAL-OPS-S2K
Sep 13, 2008 05:49 PM
Spec_Ops2087
Jul 29, 2008 10:30 PM
