Transmission?
Sent from my VS870 4G using Tapatalk 2
So, what exactly did you broke in the PPG dog box when your shifter moved all crazy?? did you find out the weak link on the dog box ppg setup on your 9 sec passes?
Still very interested to see how the PPG option works for people. The stock transmission in the S2000 is one of the best transmissions in terms of shift feel and throw in the world, all we need to do is successfully fortify it, prove it and work with what we already have.
Matty in the UK has just terminated his second stock transmission,2nd gear let go. You may have your work cut out modifying the stock setup because even if the gears are made stronger the casing will be the next thing to let go.
It really suck's how weak this transmission is took apart my blown ap1 trans 2nd gear on the main shaft is has no teeth on it, not even worth rebuilding to me can't buy just synchro's must buy the hole gear set. To repair this I would need to replace main shaft and 2nd gear set and still have old synchro's on all other gear but 2nd. Yes I was banging gears lol
