Transmission?
Old Apr 27, 2011 | 11:13 PM
  #121
robbi's Avatar
Originally Posted by Sinan'S2000
Originally Posted by redboost10' timestamp='1303620007' post='20500899
here is mine...
are you sure that this is a e36 m3 six speed transmission? zf 6 speed is 3 piece and much wider.. also getrag 6 speed too
In my project we'll use all m3 parts. We changed transmission choice. 5 speed zf e36 mk1 mk2 m3 gear ratios are longer and more useful for drag racing and also strength is incredible. I'm also using e36 m3 3.23 differential, axles and driveshaft. I will post picture when we will finish the project.
Baller
Old Apr 27, 2011 | 11:17 PM
  #122
godmachine's Avatar
here is mine...
Long first gears for drag racing and a 3.23 rear ? WTf you trying to do 100mph in first
Old Apr 27, 2011 | 11:35 PM
  #123
redboost10's Avatar
its not a e36 tranny. read the above posts. Sinan quoted my posts. He is the one running the e36 trans. i was just posting a picture of the trans im using.
Old Apr 28, 2011 | 12:49 AM
  #124
godmachine's Avatar
Dude I know thats a gf5r trans. When I hit reply it just dragged your post with it.
Old Apr 28, 2011 | 07:02 AM
  #125
redboost10's Avatar
ok, i see. haha. thanks man
Old Apr 28, 2011 | 02:28 PM
  #126
Sinan'S2000's Avatar
here is mine...
sorry Red i understood wrongly then what kind of transmission that is? American?
Old Apr 29, 2011 | 10:08 AM
  #127
Originally Posted by godmachine
Originally Posted by Sinan'S2000' timestamp='1303937497' post='20514187
[quote name='redboost10' timestamp='1303620007' post='20500899']
here is mine...
[/quote]
1. 46mph 2. 77mph 3. 116mph 4. 155mph 5. 192mph with 3.23 rear end.
I think these ratios are good for drag racing and also for autobahn racing
Old Apr 29, 2011 | 10:20 AM
  #128
redboost10's Avatar
its a gforce 5spd clutchless trans
Old May 2, 2011 | 05:25 PM
  #129
Angel@RaceLAB's Avatar
Just noticed some guys on here mentioning the Z33 trans and a Tremec T56 so i figured i'd post some of the stuff we are currently working on for our personal cars.
I am making an adapter plate for a faceplated TKO600 on an F series that is going in my 2nd gen rx7.
F series bellhousing has been all measured up and machined and the plate is machined with the TKO bolt pattern and now has to be cut along the outside radius to match the housing at the appropriate angle and welded.
Had a custom twin made by Competition clutch with TKO splines.
I'm currently having a pilot bearing bushing machined to take up the size difference between the s2k bearing and the TKO input shaft snout.
I also purchased a hydraulic release bearing that converts the s2k bellhousing to push type.
Also in the works is an adapter to run a Z33 trans behind a K series that will be going into my partner's 240sx.
We currently have a plate machined with the K series engine bolt pattern in it and have taken apart the Z33 trans to get the housing and input shaft machined. We will also be using a competition clutch twin on it and using an aftermarket hydraulic release bearing that allows use of a TOB bearing with a smaller face diameter to work properly with the small twin.
Old May 3, 2011 | 09:34 AM
  #130
neeman77's Avatar
Looks good, still waiting on a good street tough tranny setup like the Z33 or the ZF instead of faceplating.
