Trouble starting at operating temp
Old Jun 27, 2013 | 07:52 AM
SilverStreak476's Avatar
Default Trouble starting at operating temp
Having a major issue with this. Starts cold perfectly, but once up to temp it won't restart without a fight. Pump the gas it'll fire up, run a few seconds stall. This repeats at least 5 times before it will continue to run. If I shift into gear and catch it while its running for the first few seconds car will drive fine.. until I stop at the first stop sign then it dies. Makes it hard to take this car anywhere. 1000cc injectors, haltech computer, oem manifold and tb, precision turbo set up. Is it heat soak? Tuning? Consequence of large injectors? Needs ideas and advice. Thanks!
Sent from my Galaxy Slll
Old Jun 27, 2013 | 08:13 AM
b.r.i.a.n.'s Avatar
sounds like it needs fuel. pull up the post start enrichment table and add fuel in that area.
Old Jun 27, 2013 | 08:41 AM
sohc_mshue's Avatar
Yep tune needs adjusted
Old Jun 27, 2013 | 09:10 AM
Timmay208's Avatar
do you have a wideband? could be rich or lean. My car does kinda same thing after warm i need to get in and adjust warm start
Old Jun 27, 2013 | 07:11 PM
I'm not a tuner, so I wouldn't know how to go about adjusting it. I do have an AEM wideband, with AEM air/fuel gauge but I'm not sure how much I trust it. The tuner did not use my wideband, he used his own. I have the haltech disc and a pretty good knowledge of the parameters and where numbers should be, can anyone step me through it?
Old Jun 28, 2013 | 06:05 AM
Timmay208's Avatar
well watch you wideband, see if its lean or rich when its doing this
markforrester99
Nov 6, 2018 09:52 AM
braeden
Apr 18, 2016 09:27 PM
s2k.igor
Nov 18, 2010 09:16 AM
hondabim
Apr 7, 2010 06:38 PM
The Reverend
Apr 17, 2002 05:52 PM
