turbo and EGT temps
Old Mar 5, 2008 | 01:01 PM
mpower22's Avatar
Default turbo and EGT temps
What are you guys seeing for EGT temps and what turbo are you running? I'm getting the basic greddy kit and wondering what temp manifold coating I should go with? I assume something good to 1700F would be fine?
Matt
Old Mar 5, 2008 | 03:24 PM
Spec_Ops2087's Avatar
I've never seen anything hotter then ~1400F and thats when my fuel pump was crapping out (running very lean).
On average I see 900-1200F.
Old Mar 6, 2008 | 09:38 AM
sunhita's Avatar
how do you protect the downpipe and manifold from that heat issues?
is the wrapper adequate?
Old Mar 6, 2008 | 10:42 AM
The downpipe / manifold will always be that hot, its designed to flow 1000+ degree gases through it
Headerwrap actually makes the pipes hotter so if anything, that would be a bad thing for what you want to do
Old Mar 6, 2008 | 12:21 PM
2QYK4U's Avatar
I am not sure what the exact EGTs are supposed to be. On my wife's Evo, they vary so much it is crazy. The EGTs vary depending on what gear I am in and what load the engine is under. The EGTs have gotten as high as 1600 degrees under WOT though. Cruising temps seem to be around 1200 degrees.
neeman77
Aug 2, 2013 11:56 AM
Eric220
Jul 15, 2012 07:05 AM
Sergei
Jun 27, 2012 09:55 AM
03silver2000
Sep 18, 2008 03:42 PM
2QYK4U
Jan 23, 2007 06:59 AM
