Turbo manifold/downpipe studs
Old Jun 29, 2008 | 11:58 PM
NFRs2000NYC's Avatar
Default Turbo manifold/downpipe studs
We all know that turbo nuts that are on the studs connecting them to the manifold/downpipe have a nasty habit of backing off, causing exhaust leak, thus, burning everything in their path. I would like to replace the solid studs to some that have holes in them, so I can place wire ties to make sure the nuts can't back off. Any help pointing me in the right direction would be appreciated.
Old Jul 1, 2008 | 01:00 PM
gotswap's Avatar
I think I am going to follow the advice of several other people on here and do a small tack weld on each bolt to prevent this.
Old Jul 1, 2008 | 01:07 PM
devs2k's Avatar
mine are safety wired; my shop (scott up in NH) just drilled a hole through the bolts/nuts
Old Jul 1, 2008 | 01:46 PM
That's basically what I'm trying to do.
Old Jul 1, 2008 | 01:47 PM
devs2k's Avatar
you can just drill a hole through what you have then rather than buying special bolts for it? i am not sure
Old Jul 1, 2008 | 02:43 PM
squirrels2k's Avatar
u can do it yourself or have someone do it. you can even buy a kit to do it. clamps down in a vise and has a guide for the drill bit. adjusts for lots of bolt sizes. i think summit has them.
Old Jul 1, 2008 | 03:20 PM
Slows2k's Avatar
Buy a metric safety wire drilling jig or get some Stage 8 locking bolts.
Old Jul 1, 2008 | 03:28 PM
geists2k's Avatar
[QUOTE=devs2k,Jul 1 2008, 04:07 PM] mine are safety wired; my shop (scott up in NH) just drilled a hole through the
Old Aug 11, 2008 | 06:51 PM
ZSAK's Avatar
hey do you know what size the bolt is for the inline pro down pipe to manifold. I just happen to loose a bolt and wanted to know what bolt I can use to replace it. Thanks again everyone
Old Aug 11, 2008 | 07:10 PM
ideugene's Avatar
Originally Posted by geists2k,Jul 1 2008, 06:28 PM
The only way to go...and my Stage 8's still found a way to get loose.
There's pretty much no way, if installed properly, that the Stage8 bolts will come loose. Can you explain what happened?
