Turbo manifold/downpipe studs
Old Aug 11, 2008 | 07:11 PM
ideugene's Avatar
Dave, I got this:
http://www.pegasusautoracing.com/productde....asp?RecId=1192
I think I'm going to do the Stage8 fasteners next because they just seem easier to deal with.
Old Aug 11, 2008 | 07:18 PM
ZSAK's Avatar
after doing a little digging i saw chefj had mentioned m8-1.25" long bolts. Is this what I would need to bolt up the downpipe to manifold. Thanks again
Old Aug 11, 2008 | 07:35 PM
Spec_Ops2087's Avatar
Stage 8 bolts is the only way to go. As ideugene said, its impossible for them to come loose if properly installed.
Old Aug 11, 2008 | 07:38 PM
ZSAK's Avatar
hmm, which satge 8 bolts? I may just put one on temporarily and then upgrade to the stage 8 bolts when they come in and change all 4 then.
Old Aug 12, 2008 | 04:26 AM
kutsujula's Avatar
i tack welded my bolts.
Old Aug 12, 2008 | 01:09 PM
MrHonda's Avatar
M8x1.25 refers to the thread diameter and thread pitch in mm, not that the bolt is 1.25 inches long. I would guess that you are looking for some bolts about 25-40 mm long but I'm not familiar with the application you are referring to. Maybe someone else can post the length you need.
Old Aug 12, 2008 | 01:29 PM
ZSAK's Avatar
ya i confirmed with Chris at inline, they are indeed M8x1.25" 25mm in length
I got some spiderweb locking washers as well and see if they will work or not.
I'll let you know how it went once the car cools down.
S2kserry
Aug 31, 2014 06:43 PM
Forcedbird
Apr 30, 2012 01:27 PM
Deception
Jun 23, 2010 12:24 PM
AndyFloyd
Mar 10, 2009 02:02 PM
SgtB
Aug 27, 2008 08:46 AM
