Turbo Ready!
Old May 6, 2008 | 10:01 AM
  #61
kutsujula's Avatar
what kit is this? whats with the lag? get the tial asap!
Old May 7, 2008 | 04:11 AM
  #62
timg's Avatar
That dyno run doesn't look right at all. The jump at 7000 rpm would be very odd even if you had a large turbo. You may want to fix your boost creep and clutch issues and then get tuned again. The turbo starts to boost around 5k rpm.
Tim
Old May 7, 2008 | 10:09 AM
  #63
bigmos2k's Avatar
This is a custom turbo kit. Everything was pieced together except the manifold!
It was made by CJB80
When I get the tial wastegate I'm hoping the issue is resolved!
Old May 7, 2008 | 10:15 AM
  #64
bigmos2k's Avatar
[QUOTE=timg,May 7 2008, 04:11 AM] That dyno run doesn't look right at all. The jump at 7000 rpm would be very odd even if you had a large turbo. You may want to fix your boost creep and clutch issues and then get tuned again.
Old May 13, 2008 | 04:53 PM
  #65
bigmos2k's Avatar
bump.bump.
what you guys think?
GODSPEED 38mm wastegate 1 yr warranty $118.00
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...0025561319&rd=1
Or TiAL 38mm EXTERNAL WASTEGATE $215.76
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...0242300576&rd=1
Old May 13, 2008 | 06:29 PM
  #66
kutsujula's Avatar
TIAL hands down, no exceptions.
Old May 14, 2008 | 11:24 AM
  #67
bigmos2k's Avatar
thanks, I plan to get a new wg sometime next week. All help/input is greatly appreciated
bump!
Old May 19, 2008 | 11:15 AM
  #68
bigmos2k's Avatar
update! installed tial 38mm wastegate! Wow what a difference! full boost is around 4,000 rpms! (holding around 10psi)
xs wastegate- was the issue , also dump tube is vented to atmosphere there were 2 large areas that weren't welded shut in the dump tube, I had them rewelded ) car runs much smoother, sounds nice and deep, boost kicks in much sooner!
Next mod:
sometime in the future- ACT 6 puck clutch, 3 inch full exhaust
re-dyno tune the car.
Corey Maurer
May 16, 2011 05:19 AM
autoeurotec
Mar 10, 2011 04:41 AM
NFRTurboTerror
Jul 2, 2007 05:08 PM
toofast4yalll
Mar 2, 2007 07:52 AM
9kREDLINEs2k
Jun 21, 2006 05:10 PM
