The Ultimate GReddy Turbo Kit Thread
Old Mar 25, 2012 | 09:58 AM
  #1481
S2KCHRIS305's Avatar
hey guys so heres my dyno graph for you guys to see what power i made on my new setup .
Originally Posted by Kitesurfer s2000
The psi 16 17 ?????
nope , im boosting 13.5 psi
Old Mar 25, 2012 | 09:59 AM
  #1482
i dont know if you guys can see its kinda small , i cant figure out how to enlarge it but the numbers are 360whp and 304trq . on dyno jet SAE
Old Mar 25, 2012 | 11:47 AM
  #1483
Nyther's Avatar
What are your flywheel (engine) power numbers?
Are you running the EMU? No lowered vtec?
Nice numbers man!!
Im always confused with those WHP numbers instead of HP numbers. If you buy a car, the specs always mention flywheel power.
Im trying to get mine tuned with local octane 102 fuel.
Still running OEM map sensor. What maximum psi could i run with the OEM map sensor? ( its relocated with the oem greddy relocation stuff so perhaps that allowes a lil more boost? )
Old Mar 25, 2012 | 12:47 PM
  #1484
I think my flywheel power is around 420hp maybe a,lil less , im running aem version 2 standalone and my vtec is set at 6300 rpms . And the most psi you can run with the stock map sensor is 10psi.
Old Mar 27, 2012 | 07:51 AM
  #1485
Nyther's Avatar
Just curious, im running 8 psi now with 300ish crank HP, what power raise could i expect if id raise the boost to 10-11 psi with a new tune? So i would gain 2-3 psi of boost...
Old Mar 27, 2012 | 09:41 AM
  #1486
You would probaly have 300 to the wheels and not the crank. Depending on what kinda exhaust system you have to.
Old Mar 28, 2012 | 05:34 AM
  #1487
Nyther's Avatar
full 3" inch berk with HFC
Old Mar 28, 2012 | 09:38 AM
  #1488
That HFC is taking some power away , swap it out with.berks 70mm test pipe
Old Mar 28, 2012 | 01:53 PM
  #1489
Nyther's Avatar
Im afraid of overboosting with that setup. I already ported the wastegate hole but i'm afraid it is not enough.
I seriously doubt if a testpipe would free enough ponies so that it's worhtwile to swap. ( i'm not bothering if it's only 10-15HP gain )
Do you have some experience with this or are those just some thoughts? Let me know!
Old Mar 28, 2012 | 03:11 PM
  #1490
I have experience with that setup and so far its been fine . It boost creeped once and I don't have ported waste gate , I think u should be fine
