The Ultimate GReddy Turbo Kit Thread
Old Oct 4, 2010 | 02:16 PM
  #971
AFs2k's Avatar
that'd be awesome if I knew how to do that...
Old Oct 4, 2010 | 02:31 PM
  #972
urBan_dK's Avatar
This post tells you exactly what to do:
https://www.s2ki.com/forums/index.php?showt...&#entry19012525
This post shows you the wires:
https://www.s2ki.com/forums/index.php?showt...&#entry19037687
Old Oct 4, 2010 | 03:04 PM
  #973
S2k.berto's Avatar
Originally Posted by itlynstalyn,Oct 4 2010, 08:29 AM
It's not like a s/c. You can't swap a pulley for more boost. You can get a boost controller and a bigger downpipe or swap the turbo if you want to upgrade.
thanks man! thats what i thought i jsut wanted to make sure. didnt want to be the guy asking the stupid question but i just needed to confirm that.
iv read every page in the thread and its extreamly HELPFULL for a newb like myself.
Old Oct 6, 2010 | 05:40 PM
  #974
snowwakerider23's Avatar
Can I run a 63mm T1R test pipe and Fujitsubo legalis r exhaust with this kit or will I have to switch back to the oem cat?
Old Oct 6, 2010 | 05:59 PM
  #975
Chris_Lum's Avatar
if the piping is larger than 60-63 mm on the main pipe, it'll probably flow too much w/ a test pipe unless you port your wastegate.
the only setups that usually work w/ test pipes are low diameter, like test pipe + stock exhaust or + HKS hi power dual.. etc.
Old Oct 6, 2010 | 06:03 PM
  #976
AFs2k's Avatar
Or port the wastegate.
Old Oct 7, 2010 | 06:46 PM
  #977
S2k.berto's Avatar
Is it possible to use ptunning manifold? Without any fabbing? Has anything like this been done?
Thanks
Old Oct 8, 2010 | 07:52 AM
  #978
itlynstalyn's Avatar
Thanks
Already asked Toan about that, it'd have to be custom fabbed. They use proprietary oil parts and engine mounts to help their manifold fit. It would definitely be less work just to get an entire p-tuning kit.
Old Oct 8, 2010 | 03:05 PM
  #979
S2k.berto's Avatar
Thanks
Old Oct 11, 2010 | 09:33 PM
  #980
$ur_Lance_uhlot's Avatar
i bought greddy ISO 6 plugs because someone recommended to me, i know the instructions said ISO 8 but the shop was very persistant to sell me ISO 6s. will they work, better or worse?
could anyone tell me what size t-bolts ill need to swap out all of my hose claps for the kit and maybe the coupler sizes?
