The Ultimate GReddy Turbo Kit Thread
Old Sep 29, 2010 | 12:09 PM
  #961
realblag's Avatar
Just an FYI. If you have the Greddy turbo kit and need to replace the timing chain tensioner, you do not have to remove anything (except the TCT lol). The suction pipe (love the name ) is in the way but if you pull out the upper bolt that holds it to the compressor housing and rotate it toward the passenger frame rail, the TCT comes right out.
Old Oct 2, 2010 | 08:26 AM
  #962
snowwakerider23's Avatar
Hi I was planning on purchasing a brand new 04-05 greddy kit for my 01, and I was wondering what all do I need to put this on besides the 01 basemaps?
Old Oct 2, 2010 | 08:33 AM
  #963
itlynstalyn's Avatar
You need to change a jumper on the harness if it's for an ap2. I'm pretty sure everything else fits perfectly.
Old Oct 2, 2010 | 10:47 AM
  #964
AFs2k's Avatar
Also, don't trust the cast manifold. They ALL crack. I torqued mine down correctly, never let it get wet... basically I took great care of it and it still cracked. I'm sure it's due to the crappy flow of it and the heat that it sees.
Old Oct 3, 2010 | 10:59 PM
  #965
S2k.berto's Avatar
hey fellas was wondering what kind of pully would i want to go with if i ever wanted to consider an upgrade?
im about to swap out the serpentine belt on my 05, i hear a slight squeek and was hoping to for a pully upgrade.
thanks guys
ALSO what coolant do you guys run? normle 50/50? or is there somthing else i need to consider. thanks
noob here first boosted car.
Old Oct 4, 2010 | 04:43 AM
  #966
STAIN's Avatar
Chris, is greddy making a stage2 kit for the s2000? do you know anything about this?
Old Oct 4, 2010 | 08:29 AM
  #967
thanks guys
It's not like a s/c. You can't swap a pulley for more boost. You can get a boost controller and a bigger downpipe or swap the turbo if you want to upgrade.
Old Oct 4, 2010 | 08:47 AM
  #968
Chris_Lum's Avatar
i think they are still considering the high boost kit. which would be something like hardware only, larger turbo, and you get your own engine management.
Good news for current Greddy kit owners though is that *i believe* they are working on a revised manifold again.
Old Oct 4, 2010 | 01:31 PM
  #969
AFs2k's Avatar
I hope they do revise the manifold. It's junk, and they all seem to crack. Thats the only problem I've had with the kit. Even so, that's still a BIG part of the kit...
If they do upgrade the kit, hopefully it'll come with a harness that will let you control vtec... that's another thing I hate about it.
Old Oct 4, 2010 | 01:56 PM
  #970
urBan_dK's Avatar
It's pretty easy to fix their harness. You have to move JP17 to 1-2 and wire the VTM pin through the EMU instead of just doing a passthrough.
