Update: Greddy Turbo Kit Dyno
Old Apr 28, 2008 | 08:32 AM
  #21
AndyFloyd's Avatar
why dont you have the compressor upgraded to a 20g wheel. The 20g will flow 400whp as long as that turbine can handle it...which is hard to tell. Its a quick spooling turbo so i most likely has a smallish turbine.
Old Apr 28, 2008 | 08:35 AM
  #22
Revenge's Avatar
You may want to get that clutch fixed your results could increase.
Old Apr 28, 2008 | 09:34 AM
  #23
devs2k's Avatar
i think there is a guy in the UK doing this; i'm anxious to see how it turns out
Old Apr 28, 2008 | 10:09 AM
  #24
brainwo's Avatar
To be honest.. if you buy a greddy turbo kit and change things around or try to upgrade to get your high hp goal, than why buy greddy turbo kit at the first place?..
i am taking the greddy the way it is and upgrade at min cost.. hg injector, and my own labor..
if i want 400+ hp i go with gt30 ..
Old Apr 28, 2008 | 10:12 AM
  #25
devs2k's Avatar
im confused; you are saying why would you modify the greddy kit, but you are modifying it?
Old Apr 28, 2008 | 10:28 AM
  #26
brainwo's Avatar
injector is free.. hg is not part of the kit..
Old Apr 28, 2008 | 10:30 AM
  #27
devs2k's Avatar
any reason you do not want to keep it on stock compression? 13psi on a 3mm HG.. isn't that very similar to running 7psi on stock compression in terms of effective boost?
Old Apr 28, 2008 | 10:52 AM
  #28
brainwo's Avatar
Experience What it can do. it only 2mm hg. i stop at 13psi because clutch won't hold anymore, i still end up with more hp and torque.
Old Apr 28, 2008 | 10:53 AM
  #29
devs2k's Avatar
i'll be curious to see what happens at 16psi
fyi, im making a little bit more power than you are, on a dynapack on stock compression, 7.5 lbs, 550cc injectors
Old Apr 28, 2008 | 11:36 AM
  #30
Lucky7s's Avatar
Well here is the basic map for the Compressor you are working on:
at 13 PSI with a 1 PSI drop across the FMIC, you are looking at a Pressure Ratio of 1.95.
If you are making 13 PSI by 3500 RPM and keep it until 8000 RPM you CFM numbers would look like this - Compressor Map Calcs
Plotting those onto the Map gives you a efficency window of this:
This is assuming everything is perfect your efficency is falling off on the top side to the point you are at roughly 68% (and most like less as this assumes perfect conditions)
Getting more Info and finishing this post up tonight, but I think that attempting 13 psi on this turbo is a bit out of its range. All you would do is generate alot more heat on the top side which would result in a loss of HP where you thought you would have more.
