Updated Power Chart
Old Dec 16, 2011 | 10:59 AM
  #61
TurboCongo's Avatar
New numbers, 62/62BB, 2000cc injectors all the same as before except threw a berk 3" and on E85
Old Dec 24, 2011 | 08:48 PM
  #62
Killer_B's Avatar
Username: Killer_B
Turbo/Supercharger Kit: Inline Pro Log
Turbo/Supercharger Make/Size: PTE 5862
Motor: F22
Compression Ratio: 11:1 (Stock)
Specs: Stock motor
Injectors & cc: FIC 900's @ 60% duty cycle
Fuel Pump: Aeromotive 340 intank feeding a 255 in-line Walbro
EMS: AEM Series 2
Fuel: e85
PSI: 17
WHP: 491WHP
WTQ: 322WTQ
Dyno: DynoJet
Additional Specs: 3" e-cutout/stock exhaust, FuelLab FPR @ 80psi, Tuned by Race Lab (Miami)
Old Dec 24, 2011 | 10:50 PM
  #63
adidas_man's Avatar
Username: adidas_man
Turbo/Supercharger Kit: Vortech V3 supercharger w/ Maxflow Power Cooler
Turbo/Supercharger Make/Size: V3 SCi
Motor: F22
Specs: Stock
EMS: AEM Series 2
Fuel: ID1000 injectors, 91 oct, Aeromotive 340 fuel pump
Exhaust: Invidia N1 dual w/ Megan racing test pipe
PSI: 10.4 PSI
WHP: 389WHP
WTQ: 245WTQ
Dyno: Dynojet
Tuner: John Tran @ JT Autosports
Old Jan 12, 2012 | 06:27 PM
  #64
Batbite's Avatar
Originally Posted by Jumpman2k
First off, nice job, and thanks A suggestion/question -- any chance this could be imported into Google Docs and linked as read-only from there?
- - - oh and it would be sortable & searchable, too.
As requested, there is now a link to the same "full-size" updated chart on Google Docs
You are welcome to check it out, sort or what ever you'd like.
Old Jan 12, 2012 | 06:31 PM
  #65
Batbite's Avatar
Chart is also updated with the most recent info from the last few members.
....sorry for the delay in getting it done, I was kinda lax over the holidays.
Old Jan 13, 2012 | 08:15 AM
  #66
Jumpman2k's Avatar
BTW for anyone checking out the new spreadsheet:
Click on the "View" menu, then "List". Then you can easily filter the list. For example, you can select "PTuning" in column B and it will only show the PTuning results. Give it a try!
Old Jan 22, 2012 | 05:45 PM
  #67
o'malley_808's Avatar
New turbo setup
Turbo Kit: Pfab equal length
Turbo: Turbonetics BB 6262
Motor: F22
Compression Ratio: SCE 2mm
EMS: EMS V1
Fuel: 94 Octane + 100% Methanol direct port
PSI: 23psi
WHP: 585whp
WTQ: 400WTQ
Dyno: DynoJet
Old Jan 30, 2012 | 09:02 PM
  #68
mezzfin's Avatar
new data for me on a new setup:
GT3076r turbo
ERL-built short block
Berk HFC
Invidia Q300V4 exhaust
Pfab log mani
14 psi
350 whp
237 torque
ID1000cc injectors
Hondata Flashpro
SOS sport clutch
Thanks
Old Feb 18, 2012 | 06:48 AM
  #69
cmn's Avatar
cmn
Username: (kind of says itself, but cmn
Turbo/Supercharger Kit: FullRace ProStreet
Turbo/Supercharger Make/Size: Garrett GT3076R .82AR
Motor: F20C
Compression Ratio: stock (11,7:1?)
Specs: Stock engine, unopened
Injectors & cc: ID-1000
Fuel Pump: Walbro 255 lph
EMS: AEM EMS
Fuel: pump gas (called 99 in Norway, but think it's what's equal to 93 in the US)
PSI: 13 PSI
WHP: 420,2 WHP
WTQ: 420,7 Nm / 310,2 lb-ft
Dyno: DynaPack
Other mods: Skunk2 68mm TB,OmniPower 4bar map sensor, custom 3" exhaust split to 2x2,5" by the diff
Old Feb 18, 2012 | 10:15 AM
  #70
Batbite's Avatar
Chart is updated...... 2/18/12.
