upgrading boost to 380+whp
Old Aug 13, 2015 | 09:17 AM
taifei's Avatar
Using Walbro 255. I would love to not have to go through the body contorting task of messing with the fuel pump again if I don't have to.
Old Aug 13, 2015 | 09:30 AM
s2000Junky's Avatar
Chitoki wants you to spend a lot of money
Old Aug 13, 2015 | 09:33 AM
s2000Junky's Avatar
Originally Posted by taifei
For me, I'm just going to put the 3" pulley on and take what I can get. I was more concerned about any other reinforcements or upgrades I might need to keep the car running healthy and smoothly. Currently I am running a 3.6" at 8psi making 213/329 @ 8400 (I think the dyno reads high though). This is also on a stock cat which I plan on going with a HFC hidden underneath the oem heat shield.
329whp/213 trq is right in the mid/upper range of what I expect for 8psi on this set up, however im a little confused as to why your only seeing 8psi out of the 3.6 pulley. You should be netting closer to 10. Are you at sea level? If so, maybe you are getting some belt slip at the top end. Actually 213trq is pretty high for 8psi, but hp is closer, so that tells me you are likely getting belt slip, because max trq is made lower in the rpm range before belt will start to slip. So you will yield a normal trq number but less hp in that case. I bet you could be making closer to 10psi and 345whp with current pulley.
Old Aug 13, 2015 | 09:44 AM
s2000Junky's Avatar
Not needed. And ID 725 will be enough, even if you had to bump up the fuel pressure a bit with an adj fpr. Those are good injectors. If you were running a NV1200 at full speed id tell you to get 1000cc.
Old Aug 13, 2015 | 11:11 AM
Chitoki's Avatar
You know how that boost bug is! Its how I do things, I went with high end support mods then when it came time for the smaller pulley, only needed a retune. I stock up on parts and such as it is.... you know the sellers around here, even OEM oil filters are mint and rare.
Old Aug 13, 2015 | 11:14 AM
s2000Junky's Avatar
I get it, however short of the upgraded heat echanger, the OP has all the support mods he needs currently to max out a NV1000.
markforrester99
May 16, 2016 02:13 AM
Brannonanand
Mar 13, 2015 11:15 PM
CourageOO7
Oct 1, 2009 11:19 AM
freshs2k
Nov 15, 2007 01:16 AM
AusS2000
Jun 19, 2007 05:38 PM
