VitTuned S2000 Project Begins
Old Aug 8, 2014 | 07:31 AM
  #41
mugen_rsx09's Avatar
That was fast!
Old Aug 8, 2014 | 03:47 PM
  #42
VitViper's Avatar
Originally Posted by 3en
Looks good! How'd you enjoy that clutch job?
That was the best part
Old Aug 8, 2014 | 08:05 PM
  #43
VitViper's Avatar
Did some quick street tuning on WG pressure just to clean up fuel and check initial timing. Not bad power for 4psi on a 3psi spring.
Old Aug 9, 2014 | 10:49 AM
  #44
VitViper's Avatar
Now i just need to wash it
Old Aug 12, 2014 | 07:50 AM
  #45
2 Ravens's Avatar
Nice build sir. I've heard a ton of good things about you from the 8th gen community, you actually e-tuned my brothers car. He's damn happy with it. Keep up with the pictures!
Old Aug 12, 2014 | 12:56 PM
  #46
3en's Avatar
3en
I know he's been pretty busy this past weekend. I stole these from his FB to post. Im sure he wont mind...
and this one is a good comparison between a s/c and turbo
Old Aug 12, 2014 | 06:00 PM
  #47
9KRPM2.0's Avatar
I like how you kept the front grill on after the IC install. I had done the same and now we look the same
Old Aug 12, 2014 | 06:02 PM
  #48
VitViper's Avatar
Finally got caught up... some more details about the final build.
Those power figures are on 92 octane Oregon junk fuel.
- Deatschwerks DV2 1200cc injectors
- Deatschwerks DW300 fuel pump
- HKS 76mm exhaust
- PRL Motorsports turbo manifold, intercooler, piping, downpipe.
- Comp Turbo CT4X-5862 .82 a/r
- Turbosmart Hypergate-45 wastegate w/ 3psi spring
- Turbosmart RacePort BOV
- AEM Fuel rail & FPR (60psi base pressure)
- Exedy Hyper Single clutch
- Our own vacuum block
Some general thoughts:
- The 1200cc injectors are working fantastic, at the 472whp power level they are @ 67% duty cycle. We will break 500 (which is our goal) on E85 at 15-16psi for sure. Maybe, just maybe, we'll be able to squeeze a couple more lbs out of it (pipe dreams, lol).
- The fuel pump is still on stock wiring, not upgraded to get 14v. There's room for more power by upping the fuel pump output.
- A couple people have asked me about the torque up & down -- I had a limited amount of time on the dyno as I had a customer to take care of, so I was adjusting the boost control PID settings and didn't have them quite how I liked them yet, got it all cleaned up on the street today.
- People have noted "why such slow spool", answer is -- it's not actually slow spool, but a very fast ramp rate on the Pack to keep the cooldown period between runs low due to time constraints (see above note). Later that night I did two street pulls, one in 3rd and one in 4th. 3rd gear has target boost @ ~5300 rpm and 4th is around ~5100 rpm, so basically shift the torque curve over about 1000 rpm's.
Some turbo noises, PRL did a fantastic job putting the kit together.
https://www.youtube.com/watch?v=a7MIih6E1wg
Old Aug 13, 2014 | 12:00 PM
  #49
Redline S2K's Avatar
Nice build and awesome results. Guy at my dealership is in the middle of having you etune his Civic with a CT blower on it.
Old Aug 13, 2014 | 05:00 PM
  #50
VitViper's Avatar
Why build cars? To get the kids hooked early
