vortech charger rebuild?
hi all
i have a plan to rebuild my vortech charger with my friends cause of making some noise like drrrrrr drrrrrrr drrrrrr around 1000 to 2000rpm
but i have no information about the bearings.
i found a site
http://www.starrland.com/Supercharger%20re...s%202-22-08.pdf
and....https://www.s2ki.com/forums/index.ph...#entry15919215
but the first one is for the maxima and other link is for s2k's NOVI1000.
i wanted to send my charger to Vortech directly for the recondition but im out of the states now.
so i decide to rebuild it in here.
pls advise the bearings and parts what i need.
thank you in advance......
i found a site
you can buy a rebuild kit from superchargerrebuilds.com. if you want to source your own parts (i found that it is much more expensive than buying the kit) then you should do a search to see if anyone else has cracked open the vortech blower and found the bearing numbers. but the source you found has bearing numbers. even though you say it's for a maxima, if it's the same blower model that's all that matters.
Akilldema
Jul 13, 2007 03:09 PM
