Vortech SCi trim charger
Old Mar 26, 2009 | 08:12 PM
  #21
leo520's Avatar
Originally Posted by s.hasan546,Mar 26 2009, 07:13 PM
idk where the link is but pm juntuned and he'll show you. he also got dynoed on a dynojet or mustang dyno. he does have a lot of mods but OP put down 389 whp on a dynapack with a ems. Mr.honda did almost the same with a kw kit and a ap1 cam and a vafc.
with that kinda work, it's better to just get a turbo...
Old Mar 26, 2009 | 08:17 PM
  #22
Randizzle88's Avatar
wow great numbers on a AP1
Old Mar 26, 2009 | 08:38 PM
  #23
Spec_Ops2087's Avatar
Originally Posted by hamlet9634,Mar 26 2009, 10:13 PM
it's 9hp different just by taking the silencers out (see the partially tuned 389hp graph vs the 380hp tuned graph). I think going with a more open 70mm DUAL exhaust and a high flow cat (the above was on stock cat) along with a less restrictive intake (the one from vortech is a bit tight) should do it.
Only way to know for sure is to do it. In a couple months, it'll happen. Phil gained 20hp by going w an Asura Design exhaust. I expect similar results.
Ofcourse I could just drive down the street and strap into Church's dyno and I'd get over 400 hp tomorrow!
I only gained about 10hp (405-->415) by going from invidia dual to a full 3" single so as I said, 40hp I think is a little unreasonable
Old Mar 26, 2009 | 10:11 PM
  #24
dragtek's Avatar
great numbers. what boost did the 4inch pulley yeild?
Old Mar 27, 2009 | 12:00 PM
  #25
hamlet9634's Avatar
4inch pulley yields 12.5psi @ 9K RPM
that 40 hp I'm hoping for is by going from a skunk II exhaust w silencers IN to a more open 3"dual without silencers (figuring 10 hp from just taking out silencers and maybe another 10 w the whole exhuast)..
AND high flow cat
AND revised intake.
And maybe you're right 40hp is hopeful. But I'm hopeful.. haha!
Old Mar 27, 2009 | 12:19 PM
  #26
John_Z's Avatar
What's the inlet diameter of the SCi snail?
Old Mar 27, 2009 | 12:25 PM
  #27
Asura's Avatar
Sean, I am thrilled that you are completely satisfied with your new set up.
I think the shorter gearing adds to the 'lively' experience
Two new Asura products will be released this coming Wednesday...
Old Mar 27, 2009 | 12:56 PM
  #28
klimaxx805's Avatar
Great numbers! I've been waiting for someone to post up AP1 SCi-Trim numbers, thanks.
John_Z the inlet diameter is the same as the old S/SC-Trim, 3.5". The only one that is larger is the T-Trim, 3.75".
-Frank
Old Mar 27, 2009 | 03:39 PM
  #29
John_Z's Avatar
-Frank
Thanks Frank
Old Mar 27, 2009 | 03:40 PM
  #30
John_Z's Avatar
I can't wait to see what they are
