vortech t-trim boost level
Old Nov 10, 2008 | 05:31 AM
Jay-Z's Avatar
Default vortech t-trim boost level
T-Trim owners,
i have a t-trim vortech with a 4.2 inch pulley on my ap1. Im trying to figure out what my max boost is but cannot find a chart for t-trims. Can someone help me out? My goal is 12.5-13 psi. Thank you
Old Nov 10, 2008 | 07:20 AM
Sideways's Avatar
Take what you have and put it on a dyno that reads manifold pressure.
What ever boost you hit at redline is max boost with that pulley. With this information you can make changes to change the boost up or down.
From a calculations point you can figure your impeller speed.
http://www.vortechsuperchargers.com/suppor...ed%20Calculator
A 4.2 inch pulley with 9000 rpm redline would give and impeller speed of 46,286.
The T-trim tends to like higher impeller speeds and you would be able to increase the impeller speed quite a bit if the boost is too low.
Old Nov 10, 2008 | 07:52 AM
chairmnofthboard's Avatar
You should be able to run that boost on the stock S trim with no problems.
blink962
May 23, 2013 10:46 AM
Wydget
Dec 23, 2011 01:53 PM
kstokell
Dec 1, 2005 04:16 PM
lsportlex
Aug 11, 2005 06:09 AM
Vortech
Jul 28, 2003 01:35 PM
