Vortech tuning issue
Old Apr 14, 2011 | 06:13 AM
gettin it's Avatar
Well, i dont have the map, but Mase and i just tuned my car on the Aem ems and ill sale you my black box for 50. I have a Ap2 and its never been touched, or opened.
Old Apr 14, 2011 | 07:51 AM
sarge1's Avatar
How would I know if I fuel flush the motor?
Old Apr 14, 2011 | 08:21 AM
Thunder-rush's Avatar
Looking at the boost and A/F I think the tuner did a good job, there's something definitely wrong with the timing. You are even making less power with boost at low revs. That's not common.
Old Apr 14, 2011 | 08:52 AM
Moddiction's Avatar
Former Sponsor
Easiest way to see is pull the black timing box out. Most likely that's what's screwed up.
Old Apr 14, 2011 | 09:13 AM
sarge1's Avatar
I don't think I can pull the box out and run safe I'm at 10 psi with the ap2 pulley and I'm also using the 5th injector which is why I'm not running lean. I just bought gettin it's box so we'll see what happens Imma get a leak down test than a back pressure test and than see if we can compare base maps and swap out the box and see if that make a difference hopefully its jus that stupid box. And just swapping it I'll be good to go.
Any other suggestions?
Old Apr 14, 2011 | 04:29 PM
gettin it's Avatar
On the way too you. Change the plugs also k.
Old Apr 14, 2011 | 04:42 PM
Sideways's Avatar
Smell the dip stick wipe. If it is strong gasoline smell you are getting washed.
Old Apr 14, 2011 | 06:41 PM
sarge1's Avatar
Ok Will do that right now. Being "washed" will make me lose that much HP?
Bernard- I just picked up the 2668's like you said. Will put those in this weekend or should I wait till the day of the dyno (Wednesday) or Tuesday?
Old Apr 14, 2011 | 06:57 PM
sarge1's Avatar
I smelled the oil on the dip stick and it does smell like gas I don't know if its "strong" tho but you can tell its gas
Old Apr 15, 2011 | 03:55 AM
gettin it's Avatar
Well, i just checked tracking and you will have it tuesday. I would wait to put the plugs in so that they dont mess up. Your not driving the car are you?
