Vortech V2 Si Build Diary
Old Mar 14, 2016 | 10:30 AM
  #41
skinsfn36's Avatar
Originally Posted by liquid_helix136
I know the plumbing for the water pump is pretty confusing. Theres a good diagram floating around here somewhere...
Also, I hope you don't mind pulling the S/C off again, cause you're going to need to do so in order to do the clutch. That's why most ppl do the clutch first.
I have the plumbing set up exactly like the SOS picture
The clutch I'm not worried about anymore, I have a friend with a shop that has done a few clutches with the s/c still on there. Helps when you have a lift
Old May 18, 2016 | 03:49 AM
  #42
skinsfn36's Avatar
Still having some issues with the water pump, it's the last piece of the puzzle before the tune.
Are these pumps notorious for failing or being difficult to prime? The pump is turning on and getting plenty of voltage, but it is not pumping into the aftercooler.
I ordered a new pump, just in case this was broken and I've also changed the flow to match this image:
Old May 18, 2016 | 05:12 AM
  #43
herecomesboost's Avatar
You're not going to be able to reach the top bell housing bolts unless you lower the engine.
Old May 18, 2016 | 05:18 AM
  #44
camuman's Avatar
some people still like to dream.
Old May 19, 2016 | 04:54 PM
  #45
skinsfn36's Avatar
The clutch is in, blower didn't have to be removed, but I appreciate the concern.
tom153
Jun 21, 2017 06:39 PM
watch0bak
Forced Induction For Sale
Oct 22, 2012 08:25 PM
jdms2000f20c
Jul 20, 2012 02:09 PM
