Walbro 400 fuel pump install
Old Feb 6, 2013 | 11:25 PM
neoleooo's Avatar
Originally Posted by spectacle
PM Neoleooo, he successfully installed the e85 version
yes and thankfully with your help. this pump runs flawless and quiet. i believe the E85 version is a little stronger than the standard 400. before my duty cycle was at 92%. now with this new pump and more HP the duty cycle is only at 80%
Old Feb 12, 2013 | 08:32 AM
Timmay208's Avatar
when you wired your 255 to the battery did you went through the factory wiring? is there a way to run your own wiring direct to the pump? im guessing you would have to drill or somethign to get wires through
Old Feb 12, 2013 | 08:50 AM
spectacle's Avatar
My 255 was direct wired through the factory wiring coming out of the top of the housing. It ran fine for almost two years this way, but did not last a day with the Walbro 400 before it melted the relay. I'm 90% sure a small hole was drilled through the housing to run the power and ground wires through to the pump itself. If I ever get around to looking back there again, I will confirm and post up. Its just a PITA to work back there and I don't feel like taking the cover off again to confirm this is how mine is setup (I didn't do the final wiring).
Old Feb 12, 2013 | 08:53 AM
Timmay208's Avatar
id like to hardwire my 255 but i dont wanna worry about any melting, and didnt really want to have to drill any holes
Old Feb 12, 2013 | 08:57 AM
spectacle's Avatar
Again, you can hardwire the 255 to the stock wiring at the top of the housing and it should be fine. But nothing bigger than a 255.
Old Feb 12, 2013 | 09:03 AM
Supradriver08's Avatar
i did the walbro 400 (e85) install over the weekend...i drilled a tiny hole to run the wires through the top hat and siliconed it up. this pump is definitely a tight fit in there with the stock fuel filter sock. lol i must say it is a really quiet pump!
Old Mar 10, 2013 | 02:20 PM
HoustonNFR's Avatar
Just installed this pump in my car and now I'm running lean! Time for a retune . Thanks guys for the info provided but do you think he zip ties will be a problem overtime in the e85 tank?
Old Mar 10, 2013 | 04:08 PM
I used industrial zip ties...so hopefully it does. I think it will cuz the filter is so tight against the bottom of the tank it's squeezing it under the top hat
Old Mar 11, 2013 | 04:02 AM
spectacle's Avatar
That doesn't sound right.
Old Mar 11, 2013 | 02:35 PM
HoustonNFR's Avatar
why not Spectacle?? i thought it would be normal because my car was originally tuned on the 340 pump. i think im going to have to take my pump back out.... unlike supradriver i dont think my zip ties are anything special and im afraid it will dissolve in my tank. ill be replacing it with stainless steal zip ties.
