Walbro 416 E85 pump
Old Dec 11, 2013 | 11:44 AM
InductionPerformance's Avatar
Originally Posted by lude92_si
looking at getting this pump so i can tune my car on E85, Question can i just plug this in like my Walbro 255 to the stock wiring. Or do i have to run a relay and wire to the battery? From what i have found i thought i could just plug this in and use the stock hanger with the filter sock that comes with the install kit and be good to go... My tuner said something about having to wire it in when i got my estimate.... anyone one know for sure???
Thanks
With most of these higher flowing pumps you can't just plug them in. They will last for a short period of time.
Old Dec 11, 2013 | 12:19 PM
APoner's Avatar
I used a fused 10ga wire from the battery to a relay under the dash. used the fuel pump fuse as the relay trigger and ran the wire to the back. grounded the pump to the frame in the back. i re pinned my factory connector on both sides.
zero issues for about 5k. Four 4+ hour road trips logged. ( the car isn't my daily)
Im using an AEM 320.
Old Dec 11, 2013 | 01:49 PM
Rugby_Guy's Avatar
Good, thats what I want to hear. I ran a 10 ga fused wire all the way back, with a 40a relay. Grounded to the frame in the back, using the stock pump wire as the trigger. Using the walbro 400. Turned the key on to make sure everything was on the up and up, and OMG, just hearing it prime let me know I was good.
Old Dec 11, 2013 | 02:29 PM
lude92_si's Avatar
OEM lines are fine correct? I'm being told that I need to replace factory lines or the e85 will ruin my lines. I thought I could just use OEM lines.......this is why my estimate was so high.
Old Dec 11, 2013 | 02:33 PM
d-bo's Avatar
Stock lines are fine. Both material wise and flow
Sent from my iPhone using Tapatalk
Spoolin
Dec 27, 2018 08:23 AM
riceball777
Jun 14, 2015 02:49 PM
08s2000CRbackinblack
May 8, 2010 02:45 AM
#172CR
Apr 10, 2009 12:26 PM
jin6
Dec 11, 2008 06:00 PM
