water injection before supercharger
Old Aug 11, 2015 | 07:57 AM
Brutus's Avatar
Part of the interest is because the blower may be more efficient and snail move denser air.
Old Aug 11, 2015 | 08:02 AM
Brutus's Avatar
Looked on the site, smallest nozzle size is .5 gal/hour.
Using 2, I would have to refill on a trip.
Old Aug 11, 2015 | 10:51 AM
s2k manic's Avatar
Originally Posted by davidc1
Originally Posted by s2k manic' timestamp='1439241373' post='23710353
i will be experimenting with high efficiency air to air with a novi 1000 if i can keep boost loss to 1.5-2 psi it should offset the high iat's i get with air to water when its 105 degrees outside as it is right now and nitrous fumigation into the air box to increase efficiency of the blower which will increase boost and give a 50 hp bump in power though none of this will happen til winter. for me i would give up 15 hp for consistent iat on track. for instance i make 360-380 12-14psi weather dependent and in this heat as low as 340 at 12 psi due to hot air so this is my reason for doing some changes if it works on the old blower a 1200 would be badass
Do you think that rigging up a CAI would help with your air temps instead of the under the hood air intake?
afraid it would create a restriction in front of the blower. i shielded my comptech airbox and opened up some areas for it to get outside air .
Old Aug 11, 2015 | 01:32 PM
cariza's Avatar
Dont over complicate yourself. Install your kit right before the Throttle body. I've run WM Injection for over 10 years now on both a Turbo IS300 and my Honda S2000 supercharged which I use for track days. All installed right before the TB, no puddling problems ever. Just check always for no leaks and that the module is working fine (AEM makes some crappy modules sometimes) A good economical system is Cooling mist, much more robust than the AEM, or if you can afford it, Aquamist. I see intake temps drop 10-15F degrees when the system comes on. I use the OEM wind shield water reservoir and it lasts a long time (weeks) using the medium AEM nozzle. All depends how much you boost. My country only has 91 octane so WM injection is a must here. You'll be happy with it.
Old Aug 11, 2015 | 08:51 PM
benes2k's Avatar
For best performance you want it as close to the intake manifold as possible. This helps keep the charge temperatures very low.
The intake air is hottest after it has been forced into the system, putting it infront of the blower will have much less effect on charge temps.
Old Aug 12, 2015 | 05:51 AM
yamahaSHO's Avatar
The air would be at its hottest immediately at compression and if you're placing nozzle in the manifold on an intercooled setup, you're far from it being at it's hottest and most effective delta. It's been proven that there is a greater benefit to spray just before the boost source and let the water take heat out as it is being compressed and drive the compressor efficiency up.
Old Aug 12, 2015 | 06:11 AM
jcunningham's Avatar
This is not what I have heard. Proof please?
Old Aug 12, 2015 | 06:57 AM
yamahaSHO's Avatar
What and where did you hear xxx?
I have actually already posted two links, one of which has good explanations about different nozzle placements. However, I can Googles for you:
http://www.enginebasics.com/Advanced...Injection.html
http://killerbeeperformance.com/download/ifog/i-fog.pdf
http://www.dglr.de/publikationen/2012/281210.pdf
http://www.alcohol-injection.com/en/...jection-nozzle
8kGoodENuff
Feb 22, 2009 09:33 PM
zerosleep
Mar 15, 2008 05:02 PM
2 fast for u
Mar 16, 2004 08:41 PM
VTEC_Junkie
Aug 30, 2003 01:17 AM
