What type of turbo
Originally Posted by Spoolin,Oct 17 2006, 10:41 AM
I was referring to the trouble of having to run coolant lines and a restrictor to the oil feed or risk blowing out the seals.
I just think ball bearing turbos are over rated and priced. I have yet to see an S put down more power with a ball bearing turbo compared to my turbo with the same boost and setup. Actually I was told by my tuner that a ball bearing turbo just isn't worth me changing to it and I wouldn't see any difference in power over mine. He actually commented that mine responded really really good with the S.
However it is a fact that a correctly maintained Ball Bearing Turbo will last 3-5x's longer that a non ball bearing turbo. Do they both make BIG power? YES Can they both be used on the same car? YES. Will a Ball Bearing Turbo maintained last much longer that a Non-ball bearing turbo. YES
Spool can be affected by the size of the exhaust wheel. So will some Non- Ball Bearing turbo spool faster than a Ball Bearing? YES However this can easily be changed by Going with a different exhaust housing again giving the Ball Bearing Turbo the advantage because of Longevity.
Originally Posted by PRS2K,Oct 17 2006, 01:41 PM
Precision SC-61
What?!?There is a huge difference between the Ultimate Racing 60-1 and the Precision SC-61 Turbo - humungous!
The SC61 is much larger and rated for approximately 680hp while the 60-1 can consistantly make 400hp, yet maxes at roughly 500hp. Spooling is much different between the two also. I considered an SC61 for my application, as it is capable of making huge power numbers, however if I'm not mistaken it doesn't spool until 5500 while the 60-1 spools at 4000ish. Personally I went with a GT35R, however my goals are much different than that of the original poster.
Again, my numbers could be off a bit here and there. I am by no means a 'turbo expert'.
Yes sorry mistake in how I laid the #'s out Precision 60-1 not 61
cost is not really a factor to me. If i go ahead and drop $1500 on a gt35r or sc61 than i wont ever have to upgrade. OR i could get a "ebay special" t3/t04e for about $500 and just upgrade later when i am looking to make more power. but then thats kind of like $500 wasted.
compared to larger turbos, T3 series turbos generally spool pretty quick for what they are. what gives the T-series turbos their "characteristics" are the exhaust/compressor wheel and trim variances.
for example, a .57 trim t3/t4 is great for a quick spool, smooth torque curve and a respectable top end. but this particular turbo combination is known for boost dying off at high rpm. the main culprit for the boost dying off is the trim.
a .60 trim 60-1 turbo will spool a bit slower than the .57 trim (due to the larger capacity flow rate of the wheel). however, a higher top end power level can be reached.
when choosing a T series turbo, the main thing to look into is the wheel. i'd say for your application, a .60 trim t series would suffice. it would start building a good amount of boost fairly early, and would probably hit full boost at @5000-6000rpm or so. you would notice very little if any boost dying off at 9k.
check out the garretts - theyve got a real popular t3/60-1 that many have had lots of success with. plus you can upgrade and get a bunch of add ons- like a stage three or five wheel, or an S-cover.
when it comes down to it- if i were to choose between a ball bearing or a standard turbo, i would go with a t-series. mainly because i wouldnt have to worry about running water lines and what not. t-series are more of a "bolt-on" affair when compared to a ball bearing gt.
. . .wish i had boost.
60-1's are old technology.....
gt30r is awesome but very pricey (compared to non BB/water cooled turbos)
gt32e......VERY good price, and is rated to 510 or 520 bhp.....i had one on my turbo gsr and i saw 10psi by 4500rpm's...not bad at all
If you plan on running only 7-8 pounds right now you should definitely look into the Garrett GT30R. You will have a nice low/mid range and spool up nicely... It will even be adequate later when you turn up the boost.
