where did you mount your flexfuel sensor
Old May 29, 2014 | 05:03 PM
  #31
herecomesboost's Avatar
Originally Posted by codybjag
i have a question what size are the AN fittings that come with the SOS kit? some people are running -8 and other -6.
Cody, they are -6AN --> 3/8"; you can use a -6AN --> -8AN (female to male) adapters if you want to go that route or if you're unable to find the -8AN --> 3/8" fittings.
Old May 29, 2014 | 05:14 PM
  #32
ScienceofSpeed's Avatar
Former Sponsor
As a side note: we've tested over 600 LPH of fuel flow through AN6 return hose (where the sensor should be located) through the S2000 as part of our dual surge tank fuel plumbing - there is no reason to use AN8 hose on the return side of the fuel system.
Old May 29, 2014 | 06:57 PM
  #33
Suprdave's Avatar
Have you guys flowed the stock fuel lines?
Old May 30, 2014 | 04:34 AM
  #34
wy2slow_z's Avatar
Originally Posted by herecomesboost
Originally Posted by siadam' timestamp='1401396412' post='23181317
Thank you,
I'm gonna order this asap.
As far as the GM sensor, did you order what is posted in this thread?
I'm using the following sensor (which also works with Zeitronix display):
http://paceperformance.com/i-1080149...ensor-e85.html
I went with the aforementioned sensor because of its more compact size.
And it's price. Also running this one
Old May 30, 2014 | 04:55 AM
  #35
lude92_si's Avatar
Same one I'm installing
Old May 30, 2014 | 06:03 AM
  #36
siadam's Avatar
Originally Posted by wy2slow_z
Originally Posted by herecomesboost' timestamp='1401411258' post='23181679
[quote name='siadam' timestamp='1401396412' post='23181317']
Thank you,
[/quote]
Thanks, does it come with the harness?
Old May 30, 2014 | 07:38 AM
  #37
lude92_si's Avatar
No you need to order that separate then just extend the wires.
Old May 30, 2014 | 12:25 PM
  #38
siadam's Avatar
Where's the harness located for this sensor?
Old May 30, 2014 | 01:11 PM
  #39
riceball777's Avatar
This is what I'm useing. Works great with my aem v2 and my zextronics ethanol gauge.
http://paceperformance.com/i-8396465...r-harness.html
That's the harness for $10
That's the sensor.
Old Jun 1, 2014 | 07:05 PM
  #40
siadam's Avatar
That's the sensor.
Thanks boss.
I was thinking, since I have a the AEM serial guage, 18-1, or 19-1 whatever it is, shouldn't I be able to output the sensor via my AEM v2 to the guage so I wouldn't need the external display??
If so, has anyone done that?
