Where to get fitting for Flex Fuel sensor
I have the GM sensor that has the SAE fuel fittings. I tried searching but am having issues finding a fuel fitting-barb in order to put it inline with the stock return.
You want a 3/8" EFI quick disconnect fitting you can get them at your local parts store it's made by dorman 800-085.5
Connector- Fuel Line | 5 Fuel Line Quick Connectors- Adapts 3/8 In. Steel To 5/16 In Nylon Tubing | 800-085.5 | Dorman Products
Connector- Fuel Line 5 Fuel Line Quick Connectors- Adapts 3/8 In. Steel To 5/16 In Nylon Tubing 800-085.5 Dorman Products
The barb fitting is a bit "safer" to use than just sliding the hose over the EFI fitting, but our fuel lines pre-rail don't carry much pressure so you'd likely not have a problem doing it that way.
silvermonster
Oct 20, 2010 03:41 PM
