Who can answer this kpro boost solenoid question
Old Nov 1, 2010 | 06:32 AM
ghettocrxsi's Avatar
Default Who can answer this kpro boost solenoid question
I cannot seem to get a straight answer from a few people I have talked to. Should I be hooking up my boost solenoid to b21 on the ecu harness?
And I want to tie in aem's fail safe on the meth controller how do I do that? Says to hook one to the boost solenoid and the other to 12v. to dump pressure?
Is that the best way or should I somehow get it setup to pull timing if something happens. I am a meth noob....
2007 s2k on k pro dual. Hondata was worthless to try and talk to as their tech basically told me to buzz off.
Old Nov 1, 2010 | 07:30 AM
jaundice's Avatar
Use this thread for boost solenoid. Works perfectly. It's how I did mine with kpro.
https://www.s2ki.com/forums/index.ph...f=142&t=766169
Old Nov 1, 2010 | 10:06 AM
spectacle's Avatar
The link jaundice provided should help hopefully. Good to see its being put to good use
Old Nov 1, 2010 | 01:06 PM
Ok cool, I will hook it up to there for the boost solenoid. Now I just need to figure out the meth...
Old Nov 1, 2010 | 03:00 PM
EternalLx's Avatar
Meth fail safe goes to the NOS wire thats hanging off the harness. Its a blue wire and should be marked E22 or E20 I forget which one but its the only wire just hanging around so you cant miss it.
Old Nov 1, 2010 | 05:15 PM
Thats what i thought, Thank you for the confirmation
Jaspah
Feb 23, 2017 11:22 PM
FinestS2k
Jan 27, 2017 02:29 PM
08s2000CRbackinblack
Sep 19, 2013 03:07 PM
liquidgsr
Oct 15, 2012 05:29 AM
jordannn93
Sep 29, 2012 09:46 AM
