Wire tuck in progress
Old Aug 3, 2011 | 07:42 AM
Suzuka_Joe's Avatar
*update. It runs! My return line is leaking because i can't build a an line to save my life.
Anyone got tips for putting the damn things together properly ?
Old Aug 3, 2011 | 07:45 AM
siadam's Avatar
Pretty straightforward. I actually use a little vasoline on the inside of the rubber to help the fitting slide in a little easier, as long as the line is cut straight, shouldn't be a problem. I wrap the fitting with tape, get it started, and either put one end in a vice, or just use two crescent wrenches if you don't have the an wrenches ($$).
When you cut it, wrap some tape around it, and then cut through the tape with a hacksaw, a cut-off wheel, or a dremel. It will smoke b/c of the burning rubber, and the tape will keep the ends from fraying as bad.
Old Aug 3, 2011 | 08:30 AM
Soul Coughing's Avatar
I bought a spare wiring harness that I cut up to extend my fusebox etc.. I did however put the fuse box in the passenger foot area, instead of the fender, as I don't like the idea of pulling the fender to change a fuse.
Pulling the fender
Extending the wires using my extra harness. Every wire was soldered, heat shrinked and taped.
Running the wires. I also ran the wire from the starter through the windshield area to the passenger fender so there's no wire going over the motor to the passenger side.
Ignore the uneven hole. My hole saw didn't work well while i was trying to cut it.
Good luck on the wiring tuck, it took a while to do it all correctly!
Old Aug 3, 2011 | 09:56 AM
s2000442's Avatar
Holy sh1t, that looks like a lot of work! Props to you for having the gonads to attempt this. I would not want to attempt this myself...heat shielding for me. Yes that means I am a pussy
Old Aug 3, 2011 | 10:49 AM
Corey Maurer's Avatar
best tip for AN lines.. spend the money on the summit AN cutters.. best thing I bought tool wise for my build
Old Aug 3, 2011 | 11:38 AM
Suzuka_Joe's Avatar
whats the best brand of hose ends and line, best quality, leak protection and heat protection? I'm thinking of ordering new Earl's swivel seal ends and 3ft of earls braided line. I need a 90 degree and a straight for the pfab kit. I know to cut the ends as even as I can with a good cutting wheel and use tape, do I need thread lock sealant on the threads for the adaptors?
Old Aug 3, 2011 | 11:45 AM
I used all summit racing ends and hose.. not a single leak in my system
Old Aug 3, 2011 | 12:03 PM
Suzuka_Joe's Avatar
thanks. i'm gonna rebuild mine this afternoon and try it again before ordering new stuff
edit, looks like its fixed. took it to a local shop and they redid my ends.
Old Aug 3, 2011 | 05:27 PM
Suzuka_Joe's Avatar
update with some shitty cell phone pics
< here's a video
Old Aug 4, 2011 | 03:34 AM
miguel329's Avatar
Looking good man, been considering doing this aswell just really dont want fuse box in fender hate too take fender out to change a fuse lol.
