Wiring help RC 650 injector clips
Old Apr 2, 2005 | 10:33 AM
Ztec's Avatar
Thumbs up Wiring help RC 650 injector clips
I am patiently awaiting my motor from Alaniz and am doing as much of the work as time permits and I was hoping someone has some experience in changing the OEM clips to the RC clips for the injectors.
The oem clips each share a common yellow wire w/ a black stripe then a different color wire for each clip but the RC clips wires are both black! Not knowing if the polarity of the two injector contacts are the same is there a way of making sure before I solder the new connectors that I have them wired right? I bought these injectors used and have no instructions - any help would be appreciated from you guys! Thanks in advance!
Nick
Old Apr 2, 2005 | 11:52 AM
Sideways's Avatar
They will work either way. I wired all of mine in the same orientation but it doesn't matter from what I have read.
Old Apr 2, 2005 | 12:13 PM
Ztec's Avatar
You are the man Phil! That's what I wanted to hear
Old Apr 2, 2005 | 05:15 PM
Slows2k's Avatar
I've called RC regarding the same issue. The verdict from them was to wire the connectors in the same orientation of the originals.
Old Apr 2, 2005 | 07:32 PM
Ztec's Avatar
Thanks for your input as well, I will solder them tomorrow - you guys rock
08s2000CRbackinblack
May 25, 2010 02:01 PM
amusepanda
May 1, 2010 07:11 PM
lotus7racer
Jul 22, 2009 09:51 AM
SPECIAL-OPS-S2K
Jan 21, 2009 02:13 PM
ex-eclipse
Mar 7, 2006 02:37 PM
