QUICK WIRING HELP... INJECTORS.
Searched and searched and could not find the answer... I am wiring in my injector clips for my Bosch 1000cc Saturated injectors and its been awhile since I worked on the car... the OEM clips have been removed for awhile and the wires layed across the intake manifold... anyway I can pretty much tell from the lengths which set goes to what cylinder but would love confirmation. I noted that each injector has a yellow wire with a black stripe feeding it 12v and then a corresponding ground wire of a different color for each cylinder. I think there is a BROWN, YELLOW, BLUE, and RED.
From firewall forward I believe the order is YELLOW, BLUE, RED, BROWN...
Is this correct?
If anyone could check for me or has a diagram please post it up so I make sure I dont screw this up!
Thanks
J
Is this correct?
Thanks
J
