WONT START WITH AEM! HELP HELP HELP! PLEASE...
Old Jan 20, 2013 | 09:57 AM
Prokaw875's Avatar
Originally Posted by s2kseven
Put the stock honda ECU back. Supposed to start.
Happened to me, but when I put the stock ECU, fired up right away. Then I put the AEM and started too. Something fishy. Sorts of priming it.
Oh sorry --- i missed that you already put the stock ECU.
Where abouts in CT?? Just checked that plug and it seemed fine. Just for shits n giggles I tried the stock ECU again and fired right up. WTF!!! I really hope the aem isn't fried! I hooked up my laptop with arm tuner and it connected and was giving feedback so that's gotta be a good sign right?
I'm from connecticut. If you need a stock and no security ecu I have two.
Old Jan 20, 2013 | 10:09 AM
Sarek's Avatar
I would try this gentleman's AEM to completely rule out that its your EMS or not.
Old Jan 20, 2013 | 11:37 AM
s2kseven's Avatar
I'm in South Windsor. Yeah good sign that you can communicate with AEM thru laptop. Although I know, if your spark driver is dead you can also communicate with ECU. So, you are not out of the loop yet. Try reseting (plugging/unplugging/spray clean) the light blue plug that I told you. Maybe there's a connection that is not touching.
Unplug it and check the pins - make sure they are in the same height and not broken. You might have jammed it before.
Old Jan 20, 2013 | 12:42 PM
averageJoe's Avatar
Maybe try this to see if the ignition divers are bad...
https://www.s2ki.com/s2000/topic/953...#entry21711746
Old Jan 20, 2013 | 12:54 PM
s2kseven's Avatar
You are not an average JOE --pro JOE
Nice work and thank you...
Old Jan 20, 2013 | 02:47 PM
Prokaw875's Avatar
Originally Posted by Prokaw875' timestamp='1358708273' post='22279301
[quote name='s2kseven' timestamp='1358686641' post='22278869']
[/quote]
Okay I'll try that! Could it also be the Crank position sensor? I disconnected it when I was trying to tuck thr plug and wire under the intake and thr middle of the 3 wires running to that plug was a shielded wire. I've never seen that before. Anyone know the importantance? And in right in Vernon. Know where Ron-a-roll and the tunnel/tunnel rd is?
Old Jan 20, 2013 | 03:10 PM
s2kseven's Avatar
Yeah crank sensor one of the most important sensor. If no signal, might as well go home in flatbed.
There is a grey plug near the throttle body. Unplug and plug it back....check the pin if not bend or push in.
If the crank sensor is bad...you need to replace it. You probably need to take the belt and maybe a tensioner. The sensor is tuck in the front cover
of the harmonic balancer. Shielded wire means to prevent any magnetic field signal that might screw/disrupt the signal.
Old Jan 20, 2013 | 03:39 PM
camuman's Avatar
If car started with stock ecu how would vrank sensor be problem. Check ignition sync!
Old Jan 20, 2013 | 06:15 PM
Prokaw875's Avatar
S2kseven. Do you have a aem we can try?
Old Jan 21, 2013 | 04:22 AM
s2kseven's Avatar
I do, but the ECU was modified to handle my digital Race technology dash http://www.race-technology.com/dash2_8_940.html .
My car is not a Honda s2000, just the engine.... by the way.
