WONT START WITH AEM! HELP HELP HELP! PLEASE...
Old Jan 21, 2013 | 11:45 AM
  #21
Prokaw875's Avatar
Originally Posted by s2kseven
I do, but the ECU was modified to handle my digital Race technology dash http://www.race-technology.com/dash2_8_940.html .
My car is not a Honda s2000, just the engine.... by the way.
okay thank you. I just figured i would check.
Old Jan 21, 2013 | 11:49 AM
  #22
Prokaw875's Avatar
So this morning on my way into work i contacted the vendor and expalined the situation to. They proceeded to contact AEM since they say the warrantee is through them and AEM sent them/me a RMA number to return the ECU to them in california. I guess the way it works is once the receive the ECU in within 3 business days they will contact both me and the vendor letting us know what the issue(if any) was and if it is covered under warrantee. I did have to pay to ship it to them which kinda sucked but oh well. Im just hoping it is sometihng covered under warrantee! If not i guess they will hit me with a diagnostic fee and repair cost. Anyone have them do ecu work before and know their pricing???
Old Jan 22, 2013 | 12:28 AM
  #23
bois2k's Avatar
They charged me 90$ to fix mine it also had warranty that includes them shipping it back to you
Old Jan 22, 2013 | 08:14 AM
  #24
Prokaw875's Avatar
Cool thank you. I should have a answer and diagnosis by early next week.
Old Jan 22, 2013 | 08:16 AM
  #25
Prokaw875's Avatar
So if it turns out to be a AEM issue which i assume it will be im starting to think what would have caused it in the first place? A voltage spike... lack of relay/fuse... Knowing the AEM is broke is only half the battle. Now knowing what caused the issue in the first place is the major concern.
Old Jan 22, 2013 | 10:49 AM
  #26
averageJoe's Avatar
Did you jump start or use a charger on the car in recent months?
Old Jan 23, 2013 | 10:26 AM
  #27
Prokaw875's Avatar
yes. i had the battery taken out and on a trickle charge. It wouldnt hold a charge when i tried a 200amp start on my craftsman jump pack so i ended up replacing the battery.
Old Jan 23, 2013 | 10:36 AM
  #28
averageJoe's Avatar
Originally Posted by averageJoe' timestamp='1358884142' post='22283911
[quote name='Prokaw875' timestamp='1358874974' post='22283440']
[/quote]
I knew it.
Blown injector drivers when you jumped it.
My aem went bad when I did the same. 6dollar fix in the link I posted.
Old Jan 23, 2013 | 10:37 AM
  #29
camuman's Avatar
so i have jump started my s2k countless times without issue. is this a hit or miss problem?
Old Jan 23, 2013 | 10:43 AM
  #30
averageJoe's Avatar
Jumping with another car/battery doesn't seem to cause an issue as I have done this countless times too. Shortly after I got a starter/charger and used that, it began to miss fire.
The drivers are only rated for 60 amps I believe off the top of my head, but spikes from these starters can go well beyond that.
Don't know why it happens. Could be hit or miss. But now I only jump with my civic if needed, and disconnect the S battery when charging.
