Working on a Z33 transmission swap
Old Aug 17, 2011 | 01:07 PM
B5254T4's Avatar
Want that adapter plate, beautiful stuff and great tranny! GB?
Old Aug 17, 2011 | 01:38 PM
penguinsintuxedos!?'s Avatar
Very interesting. A great replacement as far as manual transmissions go. I'd be interested in doing this as well
Old Aug 17, 2011 | 01:50 PM
passmans2kny's Avatar
is there anyway to tell what year a 350 tranny is?
Old Aug 17, 2011 | 02:53 PM
J-GO's Avatar
If then ends up working out i would be real interested in going this route.
Old Aug 17, 2011 | 05:31 PM
camuman's Avatar
Mf subscribed.
Old Aug 17, 2011 | 06:05 PM
Mek-Tek's Avatar
is the 05 G35 Trans the same?
Old Aug 17, 2011 | 06:12 PM
neeman77's Avatar
It actually includes some of the 2004's as well but I did not want to risk getting a non upgraded synchro 2004. The 2004-2006 have the shorter clutch pivot ball. The 07+ have a CSC which is bascially a hydraulic throw out bearing. There were problems with these with high clamping force pressure plates so I stuck with the clutch fork setup. I will keep everyone updated.
Thanks LJ I knew someone had to step up and get things going!
I agree the gear ratios are perfect for what I wanna do too, I was topping out 5th on my last setup and now I should be close to the same with this tranny.
There was one guy that put a skyline transmission up to our car welding it in which is similar dimensions and the getrag is a large tranny as well. I dont think there should be too much trouble in that sense but I will keep you all in the loop as things progress!
Old Aug 17, 2011 | 07:37 PM
Blucky87's Avatar
Glad to see someone addressing the transmission problems with the S!
Old Aug 17, 2011 | 07:58 PM
J-GO's Avatar
Are there plans for these parts to be available to the public or are they just one of stuff that you are playing with?
Old Aug 17, 2011 | 08:03 PM
neeman77's Avatar
Depending how it all works out I am sure I can get Mazworx to produce a kit, they already market a kit to put the Z33 transmission into the 240sx and a t56 on a K-series I believe.
