Zex Smart Nitrous Kit.
Old Mar 9, 2008 | 10:53 AM
FTW.inc's Avatar
Default Zex Smart Nitrous Kit.
Will the Zex Smart Nitrous Kit work on an S2000? Found a good deal and I'm curious to know if it would work alright with an S2. Thanks
Old Mar 9, 2008 | 11:15 AM
D1sclaimer's Avatar
Part #82021 and 82011 are the zex wet and dry kits that will work with the s2000.
Part #82030 is the direct port system that will work for the s2000.
Old Mar 9, 2008 | 11:26 AM
FTW.inc's Avatar
I was reading on the Zex website and one of the instructions is to "Run the white wire from the Nitrous Management Unit to the output voltage lead from the throttle position sensor." It says that the wire from the TPS should be white. Is it white in the S2000, and how would you hook up to that?
Old Mar 9, 2008 | 11:40 AM
D1sclaimer's Avatar
I have no clue on that because I don't run with a zex kit. Anybody else that can help him?
Old Mar 9, 2008 | 11:52 AM
f23power's Avatar
"bottles are for babies..real men get blown"
=P
-a
Old Mar 9, 2008 | 02:16 PM
S2KVITO's Avatar
=P
-a
Exactly I try to tell that to all the rustang ppl around my town when they brag about there NAWZ systems.
Old Mar 9, 2008 | 04:27 PM
AusS2000's Avatar
White? Dunno.
But it is the wire whose value changes with the throttle position so it ain't hard to find.
You'd use a vampire tap connector for quick and easy connection.
But looking at your question (And if any of my answer still leaves you confused) STEP AWAY FOR THE ENGINE and pay someone who knows what they are doing install it.
Old Mar 9, 2008 | 07:16 PM
FTW.inc's Avatar
i've installed this set up before on an old integra, i'm more than competent enough to do it, i just wasn't sure what color the wire on the TPS would be. Good looking out though.
Old Mar 9, 2008 | 10:42 PM
CC Lemon's Avatar
Hey, I have a zex system in my RX-8. The color of the wire will vary by car, when they say white, they are referring to the wire on the management unit. The management unit has 3 wires coming from it: the power (red: obviously taps for power), ground (black: ground for the system), and then the throttle position wire (white: taps to detect WOT to activate system). I'm not sure where this wire is on the s2k unfortunately but hope this might have helped clear it up? I've been using the same kit for a few months and very satisfied btw. Not sure exactly the results you get from the s2k but should be nice.
Old Mar 11, 2008 | 07:58 AM
FTW.inc's Avatar
bump for more info
