S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Centre Console Wear and Tear
Old Aug 6, 2011 | 06:36 PM
shane54nz's Avatar
Default Centre Console Wear and Tear
Dear all,
so the bezel that surrounds my gear stick has several scratches from when I'm wearing my wrist watch (I live in NZ, so I drive a right hand steer 1999 AP1). Now, I have thought about taking off the surface coating with solvent - but then I noticed that the silver stuff below the surface coating is ABS plastic, which would dissolve as well.
I don't really want to repaint the bezel as it would not smooth out the kinks. Decals are not an option either as I find those fake carbon ones super tacky.
Any suggestions? Thanks in advance for your help :-)
Old Aug 14, 2011 | 09:16 AM
BooGTS's Avatar
Personally, I'd sand down the scratches, prime with a bulldog type plastic prep, and repaint. Might be trouble having it match the IP surround.
Old Aug 15, 2011 | 02:43 PM
calxtreme's Avatar
I had good luck with using fine sandpaper to sand away the brushed steel look coating and polished the metallic chrome with metal polish. It sounds like you're beneath all the coating and now have exposed plastic. I would do what BooGTS says and sand it down and reprep. You can use flat black paint to get that conservative look.
Old Aug 28, 2011 | 05:50 PM
blobianco's Avatar
Get em painted they will look like mine!
Old Sep 3, 2011 | 12:41 PM
ADOBOnRICE's Avatar
Mine was also getting scratched up. It didn't look too good cosmetically. Rather than leave it like that, I got some rubbing alcohol and cotton balls, and rubbed the surface coating right off. It's kind of shiny underneath, but it's a lot better than looking at all those scratches. Plus, I'm planning on upgrading my center console eventually anyways.
GreenmanS2000
Oct 17, 2016 11:32 AM
Scottland
Oct 21, 2012 11:48 PM
silverhonda
Nov 25, 2011 06:07 PM
cbigelow5
Oct 13, 2010 12:41 PM
badboy00z
May 4, 2009 07:38 PM
