S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Has anyone used 1Z Klima Cleaner
Old Mar 5, 2013 | 09:34 AM
Jeremy Clarkson's Avatar
Default Has anyone used 1Z Klima Cleaner
Before the summer gets going I want to make sure that my air conditioner won't smell when I turn it on. I was thinking of purchasing Klima Cleaner. I was wondering if anyone had experience with it or if there is a recommendation out there for a better product. If anyone has used it I would like to know, does it work? Is it worth it? Was it easy to use?
Old Mar 5, 2013 | 10:59 AM
zeroptzero's Avatar
I've never used it, but I can give you some advice to keep mold out of your system once you get it clean. I got that bad smell once in a past Honda, a tech gave me some advice and I've never had it again in any vehicle in 20 years.
When approaching your destination with the A/C running, turn off the a/c button and just leave the fan running for the last few minutes of your trip (2-5 mins ?). That helps to blow out the moisture in the system and dries out the core/coil. If you shut down the car with moisture in the system it will attract mold, particularly when letting it sit all night long at the end of the day. It isn't a problem if you are doing short trips throughout the day, the problem is worse when you have it running for a while and then you shut down the car for long periods of time.
Old Mar 5, 2013 | 11:34 AM
Originally Posted by JFUSION
I've never used it, but I can give you some advice to keep mold out of your system. I got that bad smell once in a past Honda, a tech gave me some advice and I've never had it again in any vehicle in 20 years.
When approaching your destination with the A/C running, turn off the a/c button and just leave the fan running for the last 2 minutes of your trip. That blows out the moisture in the system and dries out the coil. If you shut down the system with moisture on the coil it will get moldy, particularly when letting it sit all night long at the end of the day. It isn't a problem if you are doing short trips throughout a day but the problem is worst just before the system is shut down for long periods of time.
That is awesome advice going right into the summer this will be very useful.
Old Mar 5, 2013 | 01:57 PM
icantbeseen1's Avatar
niceeee. ill be using that advice too. glad i saw this thread. something so simple i never thought about.
Old Mar 5, 2013 | 03:14 PM
zeroptzero's Avatar
after you click the a/c button off you can also increase the fan speed to blow out more moisture from the system.
Old Mar 6, 2013 | 05:02 AM
Hooray me!
Old Mar 6, 2013 | 05:53 PM
lol ^
i_luv_s2k
Aug 5, 2012 02:00 PM
mrdick
Jul 11, 2011 07:56 AM
J.W.
Aug 24, 2010 09:35 AM
8_ball
Jun 30, 2008 12:44 PM
