S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Interior / Map light problem
Old Mar 8, 2010 | 06:06 AM
WAFlowers's Avatar
Default Interior / Map light problem
Not sure if this is the right place to post this, but Electronics didn't seem right either.
My interior and map lights stopped working. It doesn't matter what position the switch is set to. The bulbs and fuse seemed OK but I replaced them anyway just to be safe. Still no workee.
For me it is an annoyance but my wife REALLY hates getting in and out in the dark. Any suggestions of what I should try next?
Old Mar 11, 2010 | 07:21 AM
my2ks2k's Avatar
here is one reason the light may stop working. mine got to the point where it would work randomly, then it quit all together. cleaning the contact points per the aforementioned thread fixed it back to good as new
Old Mar 11, 2010 | 07:38 AM
WAFlowers's Avatar
A friend suggested that as a problem. I'm going to look at it this weekend. Thanks for the link; the detailed step-by-step will be very useful!
Old Mar 11, 2010 | 12:10 PM
croftoncustoms's Avatar
happens to my05. Just hit it a few times and it will work. Thats how everything electric gets fixed!
Old Mar 15, 2010 | 08:15 AM
WAFlowers's Avatar
Thanks for the suggestion. That was exactly what the problem was. I dismantled it as show in the link (and thanks for that too!) to discover nasty white/green corrosion. Some WD-40 on a paper towel cleaned it right up, then I hit the contacts with some 400grit wet/dry followed by another wipe of WD-40 to try and discourage future corrosion.
It works great now!
Old Jan 24, 2012 | 03:19 PM
roosty's Avatar
also try and bend the contacts, if you can, or get some electrical grease to make sure contacts touch.
Old Jan 24, 2012 | 03:33 PM
S2k007's Avatar
LOL, I'm ashamed to admit this often works for me.
Old Jan 25, 2012 | 03:41 PM
miguel329's Avatar
yea i cleaned mine with the write up works good again
turtleesss
Nov 10, 2016 03:48 PM
DangerZone9K
Mar 1, 2013 06:58 AM
jyeung528
Jul 20, 2011 09:43 PM
emac0408
Jul 23, 2010 05:12 PM
jfw432
Feb 5, 2009 01:12 AM
