S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Need help disassembling OEM seats
Old Sep 8, 2012 | 01:16 AM
kap's Avatar
kap
Default Need help disassembling OEM seats
from what i read from my research, it said to pull the plastic handle until it comes off. at first, i thought the "plastic handle" was the lever handle, then i found out it wasn't. Do I yank on the cover? It doesn't look like it will come off as the lever slot is not big enough for the lever to fit through.
btw, sorry for the crappy pictures.
Old Sep 9, 2012 | 08:22 AM
croftoncustoms's Avatar
Pull on the handle! It will come off. Some are just REALLY on there.
Old Sep 10, 2012 | 06:31 AM
kap's Avatar
kap
What do you mean by the handle? the reclining lever? do you seriously just yank up on the reclining lever until it comes out? I don't meant to question you, i just want to make sure I don't break it lol
Old Sep 12, 2012 | 09:06 AM
manasseh808's Avatar
yeah you gotta work it, pull the lever up and out a little until you can work the cover through the lever but dont pull lever outwards away from the seat too much.
Old Sep 12, 2012 | 01:11 PM
TIME OUT!
to remove the plastic side trim off the seat there are a few things to do.
1: remove the recline handle. what i mean by this is, if you pull up on the handle (like you want to recline the back) and then pull out(toward you while facing the seat) the plastic recline handle cover will come off! if you get a pick or small screw driver and insert it into the back of the handle this will help pop it off and out.
2: there are 2 ( if i remember correctly) screws holding it on. remove thoes screws.
3: slide to plastic cover over the metal recline handle and your done.
Dont try to work around any steps because you risk breaking parts.
RobinA3
Nov 25, 2020 03:31 PM
ego
Jan 29, 2008 01:23 PM
Enthralled
Oct 6, 2006 07:59 PM
mike_awkisbig
Jun 10, 2005 06:52 AM
2kLuder
Jan 17, 2002 10:30 AM
