S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Radio dash controls
Old Aug 4, 2013 | 04:27 PM
Swaggy's Avatar
Default Radio dash controls
Can I use my dash audio controls With an aftermarket headunit??
Old Aug 4, 2013 | 05:24 PM
Kenshyn's Avatar
Absolutely. Some audio installers should have a module they can hook up to the headunit in stock, or you should check out www.modifry.com
Old Aug 5, 2013 | 05:49 AM
takeshi's Avatar
Yes but you'll need a DCI. I'd also suggest Modifry's.
Old Aug 5, 2013 | 03:07 PM
zeroptzero's Avatar
Modifry can even supply a plug and play harness if you want. I love his DCI product, and the variable speed volume option that it offers really fits well with our cars, a definite upgrade.
Old Aug 7, 2013 | 04:41 AM
mike_engr's Avatar
Originally Posted by JFUSION
Modifry can even supply a plug and play harness if you want.....
Based on what I've read, the Modifry wired DCI is the way to go, and I wanna get one too!
But I have a question about the plug and play harness.....
If the Prev Owner already (Professionally) installed a Kenwood HU, and now I want to add a wired DCI to enable the dash controls, is the Modifry PNP harness of any benefit now, or is it too late to benefit from it? Anyone know?
Old Aug 7, 2013 | 05:14 AM
takeshi's Avatar
It should be of benefit as long as the person who installed it didn't clip the connector on the S harness and solder directly to the wiring. Probably unlikely but you just never know until you take a look. "Professionally" really doesn't mean anything. There are pros that do things the right way and pros that do things the wrong way.
If that's not the case then you'd just pull the harness that was used and replace it with the Modifry harness (connected to the DCI).
Old Aug 7, 2013 | 07:03 AM
zeroptzero's Avatar
I'm willing to bet they cut the original harness and the clip is missing, in that case the plug and play harness will not work, so just go with the DCI.
LubedKoala
Mar 28, 2008 03:45 PM
LS Boy
Jan 27, 2007 03:15 AM
cshamash
Jul 17, 2006 11:00 AM
TJeep_1999
Mar 24, 2006 02:34 PM
2k3yellows2k
Dec 3, 2003 10:29 AM
