Modifry's DCI (Dash Control Interface)
Old Mar 17, 2006 | 12:01 PM
TJeep_1999's Avatar
Thumbs up Modifry's DCI (Dash Control Interface)
I didn't even know that anyone made such a thing, but it seems like a pretty straight forward idea... link the in car radio controls to the aftermarket head unit via the remote interface. I like it.
What I don't know is if this product is any good. Has anyone done this? What is the build quality? Does it work well? Is it easy to install? Is it installed behind the radio or behind the car audio controls? If it is behind the radio I'm all over that, but behind the car audio controls is another thing all together. How do you get behind that panel???
Happy St. Patrick's Day!
Thanks!
Old Mar 17, 2006 | 12:21 PM
SC_Highlander's Avatar
Bob makes good gadgets. The DCI works great. I've had both the IR and now the wired versions on 3 different alpine decks and they've all worked perfectly.
Old Mar 17, 2006 | 02:09 PM
Saki GT's Avatar
I have the infared DCI - works great. Use the wiring harness Bob sells with the DCI and its a very simple, direct set up. The DCI essentially plugs in between the factory wires to the dash controls that are behind the HU and the actual HU, so its easy to install. The Dash controls themselves are difficult to get to, but it can be done if you don't mind dropping the steering column. Fortunately you don't need to get directly to them.
I actually taped my DCI module behind the passenger shin panel for easy access if I ever wanted to change the speed settings for the volume control, fyi.
Old Mar 17, 2006 | 03:27 PM
airborne.s2000's Avatar
I second Saki's opinion. I installed the DCI into my car quite easily. There is no need to get behind the stock controls, everything plugs in behind the HU. The only piece that doesn't plug in there is the speed sensor, which does not have to be installed, though installation of the speed sensor piece is pretty simple, as well.
Old Mar 17, 2006 | 03:49 PM
w1ngman's Avatar
Hell...the speed sensor was the big sellin' point for me . But regardless, here's another to the DCI
Old Mar 18, 2006 | 01:20 PM
S2k Awe's Avatar
The speed sensor is the best part of it.
I too installed the unit behind the passenger shin panel, which is also where I installed my Sirius receiver.
I too was skeptical until I heard a few good recommendations, but I'm glad I did, because I was not going to install an aftermarket head unit that disabled my dash controls.
Old Mar 24, 2006 | 02:34 PM
HOTRODS2000's Avatar
I've had mine for three years and it still works as advertised. The auto volume control is the best part.
b000n
Oct 11, 2013 11:13 AM
Swaggy
Aug 7, 2013 07:03 AM
S2PIDSTYLE
May 14, 2008 02:22 PM
HRTS2k
49
May 29, 2007 04:48 PM
2k3yellows2k
Dec 3, 2003 10:29 AM
