S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Rear soft top tray install
Old Dec 10, 2012 | 05:31 PM
Sceanzo's Avatar
Default Rear soft top tray install
Bought my S without the soft top drains or the rear tray installed. Well I am now at the point where i want to re-install everything
I have bought all the rear plastics behind the roll hoops as well as every single nut, bolt and clip needed for the install via majestic honda.
Now my question is what is needed for this install? Will i need to pull the roll hoops first? Go through the trunk or through the cabin? I have unlimited tools at my disposal, just looking for some tips or guidance before I jump into installing everything.
Old Dec 10, 2012 | 06:33 PM
croftoncustoms's Avatar
First remove your seats. then the bottom door jamb panel. then the side trim (where your fuel lever is) then the bag hooks and that flat rectangle panel. notice a screw under a round cover on the outer side of the rool hoop plastic.The side drains go in first. notice the indentions in the plastic and how it will fit under the rear of the roll hoop. (its a bit**). once they are wedged under it there is one screw that holds both to the car under the circle piece. you should have twogrey colored tree push clips. these will fasten these two drain trim to the rear hoalf of the car. notice the metal flange with two holes in it on each side. no you can sneek the bottm tray in through the trunk. its a tight fit, take your time . that will drop in and rest on the two drain pieces you just installed. next in the longer rectangle piece. that goes above the bottom package tray. it will snap into place.
time for your tree clips. there are two screw type clips for the side drain trim pieces. the rest of the push insert clips go aling the back area.
Install your interior back and your done. feel free to pm for more help
doug
Old Dec 10, 2012 | 07:46 PM
s2ka's Avatar
Most of the soft top instructions show what's needed for the install.
https://www.s2ki.com/s2000/topic/758...p-replacement/
Old Dec 11, 2012 | 12:17 PM
Sceanzo's Avatar
Got it done. The soft top drains were a pain for sure but I got it finished
Much quieter now I'm glad I did this.
Thanks for the help everyone.
Old Dec 11, 2012 | 06:35 PM
Good deal.
CodyLX450
Dec 2, 2011 12:27 PM
S2Hey
Oct 24, 2011 04:18 AM
chrisafi213
Jul 25, 2005 12:46 PM
BlueS2000Boy
South Florida
Jan 23, 2004 05:33 AM
