S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Roll Hoop Trim Glued Together?
Old Sep 15, 2010 | 01:43 PM
LoPro25's Avatar
Default Roll Hoop Trim Glued Together?
Hey guys, quick (perhaps stupid) question. I've read through lots of info and have a pretty good indication but no confirming info answering my question about the plastic trim around each roll hoop...are the two pieces on each hoop held together simply by glue from the factory? And to put them back together do I simply need to acquire the correct adhesive for the polypropylene(sp?) plastic? There are no clips to hold those pieces together?
Old Sep 15, 2010 | 06:08 PM
Shadow_S2K's Avatar
Former Sponsor
It is not glued together from the factor. It is more like "molded" together from the factory. Once you break the two half's apart...there is no permanent solution to keep the two parts together. Many of tried all different types of adhesive all to have them separate again over time. But you can try to glue them together, it might hold for awhile.
Old Sep 15, 2010 | 06:57 PM
LoPro25's Avatar
So what do they do for a stock replacement at a dealership? Does the trim around the roll bar come as one molded piece? If so, how do you install it around the roll hoop cuz you cant put the trim around the hoop when it is stuck together.
Old Sep 15, 2010 | 07:35 PM
Shadow_S2K's Avatar
Former Sponsor
I believe they are sold as one, the roll hoop and the trip. Instead of buying it at a dealership you could try looking for a used set that pops up from time to time that has never been separated.
Old Sep 17, 2010 | 06:03 AM
LoPro25's Avatar
I just bought a set on eBay. Lesson learned, don't go seperating sh** if you don't know how it goes back together. Thanks for the help Shadow
Old Oct 17, 2010 | 01:31 AM
HRS2000's Avatar
You can seperate the roll hoops . And when you install them afterwards again just glue them together . We've done the same with my roll hoops .
sstfnv
Mar 4, 2013 03:02 PM
bryanwells
Jun 13, 2010 10:33 AM
King_
Mar 9, 2009 10:02 AM
jon3501447
Jun 3, 2006 04:13 PM
Kramer
Sep 5, 2005 09:13 PM
