S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
water leak
Old Sep 26, 2011 | 01:30 PM
bensap1's Avatar
Default water leak
I just bought my ap1 last week... this was the first rainfall and its leaking from both weather seals (front corner between the a pillar and convertable)... pretty good leaks to, nearly a steady stream and getting my seat wet... I searched and everyone seems to say get univeral, but these strips are huge and my local autopart stores just have small ones. is there a site that sells "factory" pre cut "perfect" size weather stripping? I couldn't find any...help needed please
Old Sep 27, 2011 | 05:56 AM
croftoncustoms's Avatar
there is some grease stuff that will help the weather strip keep its shape and seal. You could also consider tweaking the window a tiny bit.
Old Oct 7, 2011 | 06:42 AM
Cyclon36's Avatar
Sounds like you can benefit from a few things. One would be purchasing soft top strikers from an AP2. yours are probably worn out and not pulling the top tight to the front seal anymore as they should. The AP2 strikers are beefed up and should last longer. Regular maintenance item really if you've had the car for a while.
Second is to get some Shin-etsu grease. Should be sold at either your local honda place or you can buy it online on sites like handaaccessories.com. Your seals should be treated with the grease at least once a year to keep the rubber soft and working properly.
Jpee
Jul 20, 2018 01:18 PM
gregasorous
Sep 6, 2017 02:16 PM
Captainslow_13
Oct 2, 2014 02:47 PM
geoff2005
Jan 7, 2008 01:37 AM
Mannix16
Oct 26, 2005 05:13 PM
