Sponsored by: CARiD
06+ engine in a 00-05
Old Dec 24, 2015 | 04:06 AM
jsenclosure's Avatar
Default 06+ engine in a 00-05
Has anyone put an 06+ engine in a 00-05. Should be fairly straight forward as long as you change the crank sensor, cam sensor, valve cover, and intake manifold over to that of 00-05, correct? Can anyone confirm. Thanks
Old Dec 24, 2015 | 04:24 AM
afzan's Avatar
Also coil packs, injectors, throttle body, etc
Old Dec 24, 2015 | 06:16 AM
Coil packs work
Injectors and throttle body are on the intake manifold along with iacv
Old Dec 24, 2015 | 06:39 AM
afzan's Avatar
Originally Posted by jsenclosure
Coil packs work
They might "work" but the honda service manual specifically says coilpacks between 00-05 and 06+ should not be interchanged
There's plenty of threads on the coil packs and on 00-05 vs 06+ motor swaps its been done many times
Old Dec 24, 2015 | 08:50 AM
Great, just wanted to confirm it's a go. Thanks
Old Dec 24, 2015 | 12:06 PM
JUSTINTHECOASTIE's Avatar
From your 00-05 keep your valve cover with coils,all shortblock sensors(crank/knock), fuel rail with injectors, everything intake related, and change the 06 trigger wheel to 00-05 trigger wheel
weenrock
Mar 14, 2019 05:06 AM
james0933
Apr 26, 2017 02:25 AM
jsenclosure
Oct 29, 2013 12:36 PM
Sh0rtgir1
Jul 5, 2010 08:43 AM
VtecTuning2k
Sep 12, 2005 10:20 AM
