Sponsored by: CARiD
06+ TP w/Check engine light
Old Mar 11, 2009 | 09:52 PM
  #71
TJR's Avatar
TJR
Originally Posted by tudernos,Oct 28 2008, 05:10 PM
I pretty much tried everything to. But this time I bought the Blox from inlinefour and used 2 spark plug anti-fouler from autozone. I stuffed it with steel wool and now 100+ miles still no CEL.
Highwaystar get the blox antifouler and it should make the difference
TJ
Here is the link FYI
Old Mar 13, 2009 | 11:08 AM
  #72
Hamburglar's Avatar
TJR
those look just like the ones i got at advance auto. and i still have a CEL, however when i change my oil in the next month im going to add the steel wool and see if that works.
Old Mar 13, 2009 | 02:46 PM
  #73
HighwayStar's Avatar
TJ
TJ should i get this and try again with This and my 2 defouler on top of that? And i had an Invida 70mm what TP would be better from stopping it?
Old Mar 13, 2009 | 02:58 PM
  #74
TJR's Avatar
TJR
That's what I did
The blox and 2 antifouler
my TP is a 60mm Skunk2, I did not see anything special on the TP
Old Mar 13, 2009 | 03:02 PM
  #75
TJR's Avatar
TJR
Originally Posted by Hamburglar,Mar 13 2009, 11:08 AM
TJR
Believe me there are not the same, the blox is a little bit longer and it does not allow so much air to go in.
Old Mar 22, 2009 | 07:39 PM
  #76
skipdodoubleg's Avatar
I'm really glad I read this thread a couple times over before ordering my TP. I went with a Berk TP and the Blox from inlinefour. I've driven the hell out of it trying to get it to throw a CEL, and no luck at all! So I'll go ahead and jump on the Blox bandwagon for the MY06+!
Old Mar 22, 2009 | 10:41 PM
  #77
S_nisen's Avatar
Running Berk HFC, it worked for quite awhile (about 3500miles), but now the CEL will pop off every couple hundred miles and will pop off if I am going up a certain degree incline or it seems that way, well at least it does if I am at about 3200rpms, IAT is at about 100F, ECT is about 190~200F. This is what I get from reading the OBD2 port with the checker/clearer. I just clear the CEL and go about my way. This summer will be going with the KPro so I can just turn off the 2nd O2 sensor and never have to worry about the CEL popping off for the bogus, "hey you have no cat or your HFC is no longer cleaning up the exhaust enough".
For the guy that posted back in November, just unclip the wires at the locking clip, then you will not twist the wires when trying to remove the O2 sensor while the tp, hfc or regular cat is in place.
trojanguy1
Nov 6, 2009 12:49 PM
pistolpete17
Apr 27, 2009 03:27 PM
Hamburglar
Oct 22, 2008 11:05 AM
EddieAtATL
Oct 13, 2008 04:58 PM
MADBADGER
Dec 1, 2007 10:19 AM
