Sponsored by: CARiD
The $5 alternative to diff collars
Old Dec 9, 2011 | 04:02 PM
speedjunky01's Avatar
Default The $5 alternative to diff collars
Run down to lowes and grab some caulk off the shelf
It's not crazy stiff at 60a
3m windshield adhesive is stiffer but it's 20
the medium flaccid caulk will still get the job done
Grab the caulk gun and throw the caulk in.
Empty the contents of your caulk into the mounts I always start by filling the hole with caulk first then the outside of the mount
I used a flat pice of metal to run around the edges of the mounts to keep it nice and smooth. Ive had this same setup in the civic motor mounts for 3 years without issues.
CAULK
Old Dec 9, 2011 | 05:44 PM
mavericckk..'s Avatar
nice! would this work without taking off the mounts?
Old Dec 9, 2011 | 05:51 PM
itsnoe30's Avatar
This could just be brilliant.
Old Dec 9, 2011 | 05:54 PM
Importedpower's Avatar
Meanwhile in the projects... jk lol, i think i saw this posted on honda tech a few years ago, makes sense, but hows the durability?
Old Dec 9, 2011 | 06:07 PM
it would be tricky but could be done but it wouldnt end up as clean as mine did, once I paint them black they will look like OEM mounts
its cheap, easy, and works like a charm *insert brilliant meem here*
LMFAO Like I said in the 1st post have this same exact product in the motor mounts of my turbo civic for 3 years now with ZERO issues no cracking, flaking, falling out, separation ect ect. plus if it falls out you have a stock mount which cant hurt anything
Old Dec 9, 2011 | 06:23 PM
SH4DY's Avatar
I used this same method on my turbo MX-3 years ago except I used window weld stuff which I want to say was like 90A or something. Worked way better than the mazdaspeed mounts...
Old Dec 9, 2011 | 06:30 PM
Yeah it is stiffer but I'm a cheap mofo and yes it is softer but 1/4 of the price haha
some may say this is "below" the s2k but if it works it works
Old Dec 9, 2011 | 06:32 PM
Vitt's Avatar
..., but hows the durability?
Been used in track cars: Post #7
Old Dec 9, 2011 | 06:40 PM
nice link
reading in it aw man I didnt know they were fluid-filled
I never drilled mine but im sure it will work just as well
Old Dec 11, 2011 | 05:45 AM
Just a small update they fit right back in no problem and look great under the car impressions will be posted up in the big thaw.
