Sponsored by: CARiD
Accord calipers work on S2000?
Old Nov 19, 2009 | 03:15 PM
  #461
Neutered Sputniks's Avatar
Originally Posted by hondaf1,Nov 19 2009, 07:48 PM
i got word that Racing Brakes is sending my friend 2-piece rotors for me to try out on my car for fitment with the 03+ Accord V6 calipers. they should be here next week.
Awesome
Old Nov 19, 2009 | 03:27 PM
  #462
hondaf1's Avatar
here's some pads comparison
- top is Carbotech XP12
- bottom is OEM s2000
Notice the Carbotech pad has a curved radius towards the hat and the OEM does not. the Carbotech pad also has a large surface area.
- top is 787, 03-07 Accord V6
- second down is 503, 98-02 Accord V6
- third down is Carbotech XP12 S2000
- forth down is OEM S2000
it looks like the initial surface area of the 503 pad is larger because it doesn't have taper edge like the 787 pad.
did some tracing of the pads for comparison
pad surface area, 787 vs. 503.
backing plate. 787 vs. 503. looks like you can physically swap the pads but one will move the pad out farther.
pad surface area, 787 vs. 829 (s2000 pad)
not only the surface area is larger but the Accord pad is also thicker at 17.3mm vs. 15.8 mm. that means that i can probably go a whole race season on one set of pads and rotors. that would be so awesome
Old Nov 19, 2009 | 04:15 PM
  #463
^^^Very nice. Thanks for the work
Old Nov 19, 2009 | 05:33 PM
  #464
az3ar's Avatar
Originally Posted by robrob,Nov 19 2009, 11:02 AM
Cool,
I'm going to order a set of Accord calipers and XP10 pads.
nice let us know what happens ... with pics
Old Nov 19, 2009 | 05:35 PM
  #465
robrob's Avatar
I wonder if Carbotech's 787 pads have more contact area than stock 787s like on the S2000 Carbotech pads.
Since the Accord caliper piston is already extended when used with S2000 rotors we could have Carbotech make our pads a few mm's thicker to take up that room and last longer. They're pretty cool about making the pads the way you want them.
Old Nov 19, 2009 | 05:37 PM
  #466
s2kAtTracks's Avatar
nice posts!
Old Nov 19, 2009 | 05:48 PM
  #467
hondaf1's Avatar
i'm very excited about this. hopefully this will solve the problems of rotors cracking at the track.
Old Nov 19, 2009 | 05:54 PM
  #468
You only have the spare mm on one side...
And that's the idea behind the accord ring on the S2K hat from RB - wider/thicker rotor, so wide vanes with meaty surfaces. Should only need a washer to space the bracket to be centered on the rotor.
Old Nov 19, 2009 | 06:13 PM
  #469
NSX rotor Nearly perfect. 2 issues.
- Need about a 1/16" shim between bracket and knuckle to center. A washer would probably so but, I don't trust washers.
- Barely touches the inside of the wheel.
I'm going to shim the bracket and trim the outside of this caliper to make the rotor and caliper work. It's very close with no shimming.
Both the Type-R and the CL pads work interchangably in this caliper. The CL pad is just a touch taller.
Rotor is 28mm thick and 11.74" tall. Post my pics up in the topic if you wish. Cheapest place to get the rotor is Majestic honda. Napa is $30 more expensive but, it's just an OEM rotor.
Old Nov 19, 2009 | 06:48 PM
  #470
robrob's Avatar
If the Accord calipers aren't centered with stock S2000 rotors why would they be centered on the RB S2000 hats and Accord rings?
