Sponsored by: CARiD
ACT/CC Clutch Question
Old Jan 2, 2015 | 08:54 PM
danielx626's Avatar
Default ACT/CC Clutch Question
Hi guys I had a hard time finding which clutch I should run for my turbo setup. I recently purchased a "Full Race Front Forward Facing Twinscroll Turbo kit" (heres the link to the turbo kit: http://www.full-race.com/store/turbo...turbo-kit.html) Im assuming imma be running about 450-600 WHP which clutch would u guys recommend me getting?
ACT HEAVY DUTY PRESSURE PLATE
ACT HEAVY DUTY 6 PUCK SPRUNG
ACT HEAVY DUTY street or performance
OR
Competition Clutch Stage 4-5
Old Jan 3, 2015 | 07:43 AM
s2000442's Avatar
This has been talked about numerous times on forced induction but I will throw out my opinion. Ap1 flywheel or I like the 11lb flywheel for 550+ whp. Act pressure plate with oem honda friction disc end of story. The act friction disc chatters sometimes. Puck clutches suck. If you like driving your S on the street then forget this clutch! Don't listen to others saying it's ok and drives like stock...it doesn't! Competition stage 2 had chatter and I don't like this setup. SOS stage 2 ok but won't hold the power like the ACT setup so do it right once and forget the rest.
Old Jan 5, 2015 | 07:52 PM
B serious's Avatar
Puck clutches are so bad on the street. I guess that for the amount of power you're looking to make, you're probably stuck with the ACT option.
I'd buy a clutch bypass switch for starting the car...and don't push the clutch in except to shift/take off. Don't sit at lights and in traffic with your pedal pushed down like a fool.
I'd also use a Honda throw out bearing, high temp urea grease, and a new honda throw out bearing sleeve.
Old Jan 5, 2015 | 07:55 PM
B serious's Avatar
^I meant "stuck with the ACT option", as in the HD pressure plate and oem disk setup. That is...if you want to keep it a street car.
I really really liked the SPEC segmented clutch on my SR20DET 240SX. It wasn't making 400+hp,but it made tons of torque and the clutch held up great. Not sure how SPEC works out for S2000's.
Old Jan 6, 2015 | 12:19 PM
King Tut's Avatar
Which turbo did you go with? I would agree with the other posters and go with the ACT HD pressure plate and the OEM disk. I am most likely purchasing that turbo kit and going with the ACT/OEM combo although I don't plan to run nearly as many whp as you. Any chance you can post pics of the kit and the install when you get it?
treimche
Nov 30, 2018 04:29 AM
Stevens2000ap1
Jun 8, 2018 05:55 PM
IMSMEISTER
Aug 25, 2010 07:49 AM
AFs2k
Jan 2, 2010 09:29 PM
S2K Sideways
Apr 16, 2008 09:49 AM
